RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Castle Creation Phoenix 85HV robustness (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/9047509-castle-creation-phoenix-85hv-robustness.html)
lsjpeng 08-26-2009 05:17 PM
For those Phoenix 85HV users, how long your ESC have been used?
Mine only last 291 flights, then blew the capacitors in flight, resulted to dead-stick landing. The ESC never crashed, never over current. My typical peak current was ~72 Amp, temperature of ESC after one Master sequence was ~135F. Same settings since last year, failed in a routine practise flight.
This is the third Phoenix 85HV failed in my club. The other two had ~200 flights, same condition....... never crash or over current. Failed during routine practise with no reason. However, the other pattern flyer in my club had ~500 flights w/o any issue. All of us were using the same settings. So not sure what's the root of cause. Any ideas? Thanks!
Luke
Scott Smith 08-26-2009 05:58 PM
RE: Castle Creation Phoenix 85HV robustness
583 flights to date with no issues.
woodie 08-26-2009 06:31 PM
Luke, how does the battery lead length compare between the 85HV users in your club. Some say excessive battery length puts a strain on the capacitors. I have not had an inflight failure and my battery leads are not minimized.
Woodie
lsjpeng 08-26-2009 06:42 PM
Don:
Unlike Dale, Michael and Kevin, mine is relative longer since my battery packs are closer to the CG. I will check if there is any possibility that G-force will pull the cables onto the capacitors. Thanks!
Luke
wingster 08-26-2009 06:57 PM
It's not a physical strain. The longer leads result in more energy being dumped into the capacitors and a tendency to overheat. Many ESCs give a maximum recommended length for battery leads. If you want to run longer leads you're suppose to add extra capacitors.
lsjpeng 08-26-2009 07:17 PM
I 'm talking about 1" vs. 3" long. I don't think this is the root of cause.
Jason Arnold 08-26-2009 07:21 PM
Perhaps the capacitors don't like the big charge current when the batteries are connected?
Just my two cents worth...
Cheers
Jason.
woodie 08-26-2009 08:03 PM
ORIGINAL: lsjpeng
I 'm talking about 1'' vs. 3'' long. I don't think this is the root of cause.
Luke
I doubt that is the issue then.
Woodie
PatternPilot 09-03-2009 05:54 PM
temp seems a bit high, also if you using a connector that causes alot of arcing that could cause a issue also...
been using CC HV in pattern and small surveillance planes for 5 years without problems...
scott
SanJoseDale 09-06-2009 02:36 PM
Also, before mine died (approx 85 flights) I was having occasional synchronization problems. I have a new one from CC, have not yet decided to use it, the Jeti is working flawlwssly, thank you Don, and it's lighter.
Dale
woodie 09-06-2009 03:01 PM
Dale,
Glad it's working for ya... :-)
Woodie
