RE: CA Models ONAS
1 Attachment(s)
more.
RE: CA Models ONAS
http://www.rcuniverse.com/market/item.cfm?itemID=636431
In case anyone needs an ARC fast Thanks, Mike |
RE: CA Models ONAS
This just in from Dave S. To me its clear the swept wing planes are not for everyone but according to Dave, Tony and many others they are for them.
From Dave "The Onas is really flying good right now, probably one of the best flying planes I have ever had, the motor is working great and now whatever mistakes take place are operator error. Shoot, I like blaming the plane for every mistake but this plane just flies too good. I am still having some difficulty seeing the planes heading but the rudder is so effective it’s easy to correct" Thanks Dave, Marcelo and I look forward to seeing it at the Nats, (Approx 30 days and counting TIC-TOC, TIC-TOC) Chip |
RE: CA Models ONAS
Just finished going over my Onas, checking the trim for the Nats. It is very important to get the ailerons sealed and get the rudder trim dead straight. The model has a very powerful rudder and if there is play in the system or an offset neutral, it will drive you nuts. But when it's right, it's killer. I had a rudder cable that was slipping, letting the rudder go left. Replaced both cables and got them to proper tension and it's super.
The model at times seems a little more demanding to fly it right, but when you do it looks so good! I love mine. Best pattern model I've owned. |
RE: CA Models ONAS
1 Attachment(s)
I will be finishing mine tommorow I just need to finish install servos this one is glow Ys 170 looks like the final weight is about 10 pounds
RE: CA Models ONAS
1 Attachment(s)
The final weight of my Onas
RE: CA Models ONAS
Victor,
The plane looks AMAZING!! I cant wait to here flight reports. |
RE: CA Models ONAS
1 Attachment(s)
Well, the Nats are over and I am pleased to say the Onas and I came out on top of Masters. It was a tough week, with a mid-air with Dave Snow's Onas during the last preliminary round and a deadstick in the 1st round of the Finals. 1st deadstick I've ever had with an electric pattern model in competition. Seems the heat shrink on two of the motor connectors wore off and they contacted, frying the ESC. Oh well, 1st time for everything.
Thanks to Leon Robison for the trip, I wouldn't have been there without his support. Thanks to CA Models for a beautiful model. Thanks to Neutronics for a great motor. JR for a great radio in the 12X. And thanks to anyone and everyone who has helped me. I do appreciate it. |
RE: CA Models ONAS
Congratulations Tony. Well done!!!
RE: CA Models ONAS
Tony - Congratulations!! Great flying and way to hang in there through the ups and downs of the Nats.
Thanks, |
RE: CA Models ONAS
I was in Tony's flight group and had to fly against him every day. It was liking playing chess against a computer....
Verne Koester ORIGINAL: shannah Congratulations Tony. Well done!!! |
RE: CA Models ONAS
Hey Chip,
Does CA have an Onas ARF paint/covered ready to ship and if so what scheme? Tim |
RE: CA Models ONAS
CA Models web site link, that is on page one of the CA Models ONAS electric pattern. Has a hidden Trojan Virus, inside the link.
Do not use link !!!can RCU please remove , the like from the electric pattern thread, or let CA Models know. that there site has a " Virus" |
RE: CA Models ONAS
I am sorry I did not see your post sooner. We have one that is in the same scheme as Tony´s that is finished except we have not painted the wings. Some people like the paint others the covering. Everything else is painted. It could be finished and ready to ship by mid next week.
Chip |
RE: CA Models ONAS
I finally flew my Onas last week, it is the ARF Ultracote covered version, it flies very well, but it is still nose heavy, really didn't have time to adjust at the field.
This is my first electric 2m plane, honestly I don't like it if I compare it to my YS's, as it feels like I'm flying a two stroke, and any power correction increases the airplane speed a little bit, but I will have to get used to it, as it is the only thing I will be able to fly at 7am, as glow/gas is prohibited before 10am on our field, it does not have anything to do with dB,oh well.... What impressed me the most was the final weight, Equipment, Axi 5330 F3A CC HV80 8111 JR 9411JRx2 378Jrx2 Duralite failsafe regulator R6008HS Futaba Rx Rhino 4900 batteries Total weight 4796gr So I used a Flight power 1800mAh 7.4V for the Rx and added 96gr fro CG, but if I use the 900mAh TP I will be adding less than 40gr, and I can still change the regulator to the Power Systems Digiswitch and save 22grs more(if I remember correctly as the Digiswitch is 18grs)so it will still be under 4900gr!! I think it will still make weight using the Turnigy Nanotech I just ordered, they are heavier than any other battery, but at 70C discharge, talk about punch!!! and they can be charged at 8C! I just tried them on my Habu here in Florida, and the another guy thought I had the 3600kv motor (stock is 3200 I think) because it was as fast as his, but I'm on the stock motor, ran twice as long an as fast, really impressed by those batteries. Without a doubt a job well done by Camodel, I never thought I will have an airplane this strong and light!! Regards Alejandro |
RE: CA Models ONAS
1 Attachment(s)
Hello Alejo.</p> I just fly my Onas last week to, if you place the power battery in the try that is comming placed in the plane sure you will be nose heavy, i was moving back the battery until I lost it during a fly, almost lost the plane in the four fly. I extend the battery try, the cg is just in the wing tube, the plane fly very well, the rolls are axial, the stalls are clear and the snaps are amazing. Move from glow to electric power is not easy,to fly electric is different, you have to control the power a lot, because you have to much power. See you next week in Llanogrande. Jorge Lozano ( stati )</p> |
RE: CA Models ONAS
Hola Stati!!!!
Yes, the acft snaps are awesome, and on the batteries, that's why I did not moved them back on the field! See you next week, Alejandro |
RE: CA Models ONAS
hey you guys
it seems i'll fly an onas in the near future any flight vid's availible? |
RE: CA Models ONAS
Flew my new ONAS for the 1st time today. Very windy day so not a whole lot accomplished. Curious if there is a need for additional air flow (Exit) than what is provided by the side outlets?
Larry D2 VP |
RE: CA Models ONAS
I have never seen the need and I have no baffling in my model. I think the side vents do a really good job of drawing the air out.
| All times are GMT -8. The time now is 03:01 PM. |
