no more throttle
no more throttle
Hi!
I have a problem with my RJX 50 EP (and groupner MX12 radio)
I have changed a lot off settings on my radio and now the throttle won't work anymore. (The steering is fine). I've tested all the hardware and everything is fine. I haven't changed any parts so the problem must be with the transmitter or perhaps the esc. The weird thing is, that when i reprogram the esc and i come out of the esc menu, I can make the motor spin (not always) for like 3 seconds and then it doesn't reply to the throttle stick anymore.
some extra information:
'throttle hold' is off in transmitter
esc: red brick 70A
FBL: ACE GT5.1
radio: Groupner MX12
-edit: everytime i go in the esc menu and change nothing, i can make the motor spin for like two seconds right after i come out of the menu and then it stops. Could it be that the esc gets too much or not enough power?
esc: red brick 70A
FBL: ACE GT5.1
