Blade 300X repair
The main frame on my Blade 300X is cracked. I have a new frame. Is there a source out there to find details of how to disassemble the old frame and re-assemble with the new frame? I have not found anything useful on YouTube. Thanks.
I don't know of sources that give a detail procedure for changing the frame. I've done it a few times on my 300x. It's a major gob to do. Only thing good about it is I think all the screw heads are on the same side. I would suggest taking a sheet of paper and document every thing as you disassemble it. Such as location of esc and rx. Which way all servo face and there location. How the wires are routed . The order in which you take it apart. The more you keep track of the less frustration you will have when you reasemable it.
soddydoc (04-10-2020)
Thanks for your reply and advice. I'll use iPhone pics and lots of notes as I proceed - and I'll try to lay out the pieces in a sequential order, too. Wish me luck!
