Inaccurate servos on the aerohawk?
It seems like the servos on my aerohawk are a little bit inaccurate.
The servos will not go back to the same position when tilting the stick backward and forward. If I just tilt the stick forward and back, the servo is always going back to the same point. The same if I just tilt the stick backwards.
Is this normal?
Is this normal?
RE: Inaccurate servos on the aerohawk?
If I push the stick on my radio forward and then back to center, it always goes back to the same position. If I push the stick backward and then back to center, it always goes back to the same position too.
But this two positions are not equal! (forward-back-to-center and backward-back-to-center)
That made more sense! Only time I've seen this is when the battery is low. Usually the first indication that the battery is low is the erratic speed-up of the tail rotor, and the servos go wacky.
James
James
