Aero Hawk and cutting blades?
I have an Aero Hawk, that i have had alot of trubble with. so now/tomorow i have an aero hawk with.
Upgrades:
310 tunning motor
tunning tail motor
pro paddels
shaft collar
aluminium swash plate with ball.
Direct driven tail blade, that i don't know how to fit.
Upgraded chip on piccoboard from 8A til 16A draw current(so i could use a 11,2V Li-ion pack)
100T main shaft gear.
9, 11, 12 and 13T motor gear
Stiffen the head with carbonfiber sticks at each side.
wraped the antenna around a straw to make a "super antenna"
I also order a 3pack 11,2V 1500mAh litium pack, and a Great Plain trinitron charger.
I have a self made made 7,2V 1000mAh litium pack from nokia batteries(cell phone)
2 packs of 8,4V 700/750mAh NIMH packs.
So you can see that i have used alot of money on this heli, but i have not bought new blades, but i have 2 set's, so i was woundering how to cut one set?
Is there any hope in getting good results in cutting blades?
Do i have the right gearing?
Thanks for any replay.
If this **** is not flyable i'm going to sell this crap, but i got hooked when i had a 20sec stable hover
BTW: How do i get the gear of the tail motor, so i can connect the direct driven propeller? And the shaft on the motor seams a little short, is it?
Upgrades:
310 tunning motor
tunning tail motor
pro paddels
shaft collar
RE: Aero Hawk and cutting blades?
You did the classic **** up my friend, hehe did it myself.
None of these mods will magicly make yor aerohawk fly, flying micros is hard and setting it up correct is harder. Doing all these mods without ever having flown it does not likely head for a happy ending. The aerohawk will fly out of the box as is, some of these mods can make it more manageble if you installed and set them up right but I´l bet you didnt and your heli is propably not capable of flight now. Did the same thing myself, bought all the bells and wistles and it just got worze and worze tried it all, then went back to scratch,, and there she flew, couldnt belive my eyes, i then did the mods one by one with testflights all the way and I ended up with lots of crappy configurations. Margins are tight on this designs so there is alot of mods that require upgrading lots of other parts in correct order to make it flyable,, most likely you will get lost on the way.
I got the parts, the swashplate did the works
And the power og the 3cell lipo is fantastic.
The Trinton charger i can recomend. the orginal batterie packs charges in 25-30min, so flying is more fun.
The only bad thing with the lithium batt is that i got so mutch power that i got the heli to rocket up into the air, and I as an newbe lost total controll and it crash landed, but broke only the main blades . think i had it 10meters up, not doing that again.
Waiting for more blades, but i had spears.
Now i like the heli.
RE: <span class=
hey khmoe I am a newbe 2 and I want to order that lithium batt 2 but can you handle it? you can you fly a bit slower so you can fly it and is it esyer to fly it now? with this stock aero hawk I even can not lift after a few minutes!
thanks
thanks
RE: <span class=
Idid not no how to fly, but with the 1,5 hour charge i get 45min of flying. i Landing a lot, so 45min is not actual flying time.
But the trinitron and 3cell lithium from e-tech i can recomend.
I only need 1 pack because the motor has to cool down and i have relax.
I lent a areofly profesional flight sim that i learned to fly with lots of help on how to get the heli in if you loos control or the wind takes control over it.
I'm going out to fly some more now. cya
