How do I disconnect the piniong on the tailmotor on aerohawk?
Do I have to have special tools to take off the piniong on the tailrotor on my aerohawk?
ON, CANADA
RE: How do I disconnect the piniong on the tailmotor on aerohawk?
If the Pinion is brass, you can put the motor in the freezer for a half hour or so, then grab the motor shaft witha pair of tiny needle nose plers and use a flat head screw driver to pry against the pliers to press the pinion off. Or get a set of gear pullers
