help with bcx 4 in 1 connectors
NY
hi...... all a quick question re: the power plug to the bcx as with the bcp i am suppose to disconnect the motor from the 4 in 1 unit but it seems really hard to get a grip on it and i am worried that i might damage the unit or plug has anyone else experienced this and if so any hints as to what made it disconnect easier.
thank you.
Regards,
Phil.
thank you.
Regards,
Phil.
AB, CANADA
RE: help with bcx 4 in 1 connectors
The connectors on the Blade CP are similar, and just as tight. I used a small pair of needle nose pliers and popped them out with no problems. I don't know why I play with this micro stuff anyway, when xx-large gloves are usually too small.
Later
Brad
Later
Brad
