Go Back  RCU Forums > RC Helicopters > Electric RC Helis
Reload this Page >
Check your balls
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
Check your balls
Old 03-20-2006, 10:41 PM
cmassa
cmassa's Avatar
Default Check your balls
On the aluminum swashplate for the Blade CP that is. I just had one on a servo link come out. It looks like it has been loose for awhile. I can just push it into the hole without resistance. The hole is stripped out. Another appears cross threaded. I found this out on take off this evening and the helicopter shot to the left. Luckily no other damage (especially my CF mains). I have removed the rest and put locktite on them but am not sure how to repair the stripped ones. Other ball-links I've seen online have very short studs and I don't think they would be long enough to get a nut on the inside. Also they are rather expensive being almost half the cost of a new swashplate. I think I'll probably try a little JB Weld but am probably stuck buying another aluminum swashplate.
Chris
Old 03-20-2006, 11:02 PM
sportygreg
sportygreg's Avatar
Default RE: Check your balls
JB Weld is great stuff! I've only had one failure with JB and that's because the parts were not cleaned properly before using the JB.As long as you mix it right and let it cure long enough JB should do the job!
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
