Kyosho EP Caliber M24 Tail Problem
HI, TURKEY
There is a tail durability problem on Kyosho M24 helicopters , If you remember . Helicopter is acting unpredictable from the tail side . It's turning left suddenly which is unrelated with your transmitter commands when it is hovering . If you give full right (when it was turning to the left) , it takes 3 or 4 second to get back it is normal position . Also you can loose control of the (this is resulting with a crash in general) helicopter when it is out of control from the tail .
I examined that this unusual event is coming out after one or two minutes . You can fly the helicopter one or two minutes without any problem but after this time same problem is happening as I said above .
Are there any people who can solve this problem here ?
