Falcon 3D CP
Falcon 3D CP
I got one for hobby lobby seems to fly ok , but it drifts to the left no matter how far the trim is adjusted. what can i do? next question replacement parts are the carbon fiber blades worth the cost? How much will they effect how it flys?
RE: Falcon 3D CP
I dunno what your level is, but it sounds like you might not be far enough off the ground. You might be in GE. To get out of GE you need to go up the diameter of the rotor blades, or about 2 to 3 feet, and then this effect should be gone.
