Go Back  RCU Forums > RC Helicopters > Electric RC Helis
Reload this Page >
telebee gyro setup
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
telebee gyro setup
Old 04-28-2009, 05:53 AM
andrew100
Default telebee gyro setup
Hi,
I have a telebee gyro from hobbycity, there is an extra plug that only has the signal wire connected to it.
Can someone clarify if the extra plug is used to switch the gyro from normal to hh or is it used to adjust
the gyro gain from the transmitter?
I have a dx7, can someone direct me how to setup it up with the dx7 or some info on the setup.
Thanks in advance.
Andrew
Old 04-28-2009, 11:14 AM
ftmarino
Default RE: telebee gyro setup
If you want a quick setup, that wire will be plugged into the gear channel on your receiver. Next, in your initial setup menu on the DX7 set GEAR to GEAR. And now, yes you can use the GEAR switch on your TX to switch from HH to Normal. You can set the gain in the travel adjust menu on the GEAR channel. If you want to use what's called gyro sens it gets a little more involved but still easily doable. I would suggest some setup videos from this or other forums such as helifreak.
