RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   need help with servo setup on tx please (https://www.rcuniverse.com/forum/electric-rc-helis-167/10703833-need-help-servo-setup-tx-please.html)
almaidah 09-06-2011 05:51 AM
ok i have a exi 450 pro and i just bought metal servos for it and i am also using wk 2602 tx now my servos move the right way when i move forward and back but when i go left on the stick i goes to the right and when i go right it goes to the left. can someone please tell me what i need to change to get this to go the right direction. thank you
augerin2 09-06-2011 07:59 AM
RE: need help with servo setup on tx please
1st) are all your servos moving in the same direction?? ie; when you give + pitch they should all move up. If not then try reversing whatever servos are not moving in the correct direction. If all your servos are moving in the same direction,then you'll have to make changes to your Swash mix settings. exchange a + mix setting for an equal value in negative or vise a vera untill you get the correct inputs. up I'm not familier with that radio. Is it programable ?
almaidah 09-06-2011 08:04 AM
yes it is programmable but it dont have servo reversing the servos all move up the i throttle it just when i do left or right input the go the wrong way
almaidah 09-06-2011 08:06 AM
so do you mean i need to play with my aileron settings to get it right?
almaidah 09-06-2011 08:25 AM
this is the manual of all the things i can do with this tx http://www.rtf-heli.com/files/WK2602_TXManual.pdf
