aerohawk reverse????
I ordered the smartech aerohawk from the guy in Hong Kong off of e-bay and it should be here any day.... I forgot to tell him that I wanted the left stick throttle version. Will there be any way to reverse this once I receive the helicopter? I have only owned gas and have no idea about the little receivers, can the channels be switched just as easily as on the full size gas r/c's?
RE: aerohawk reverse????
Take a look at the answer that I wrote in this string:
http://www.rcuniverse.com/forum/m_12...tm.htm#1263515 |
yep i had the same problem it will come in mode one. these directins are awesome and it is very easy. i did it in 30 minutes. you can do it!!!!!!!!![sm=thumbup.gif]
| All times are GMT -8. The time now is 08:59 AM. |
