Help!!!
Hi everyone. Just when I thought I had my Piccolo FUN figured out, it stared spinning uncontrollably counter-clockwise at throttle over 30%. I have a Piccoloboard Plus and a headinglock module on a Piccolo FUN modified with a titanium shaft and metal bushings. The problem goes away when I fully recharge the battery, but comes back within a minute of flight. I can't lift it off or even control it in this manner, it will spin even with full tail throttle. Do I need a new battery? Do I need a new tail rotor motor? Any help would be greatly appreciated!
Sparks |
RE: Help!!!
Hi,
It sounds like your tail motor is dying:( |
RE: Help!!!
Yeah, that's what I thought too. But does that explain the behavior with a fully charged battery?
Thanks! Sparks |
RE: Help!!!
It totally explains the situation with the fully charged battery. This will happen when your main motor dies as well.
RE: Help!!!
Ah. I guess that makes sense... I wil continue pondering over the mysteries of the piccolo. Meanwhile, I will order a new tail motor. Thanks for all your help!
Sparks |
| All times are GMT -8. The time now is 04:14 AM. |
