Sandpaper the rotorhead on aerohawk
I've got a tip of sandpaper the plastic seems on the rotorhead on aerohawk for smoother flying. Now my rotorhead is very tight and it is much rubbing when tilting the head from side to side. Should the rotorhead tilt freely so just a little breeth is enougt to tilt the rotorhead, or should it be a little tight?
RE: Sandpaper the rotorhead on aerohawk
It should be closer on the side of loose but not so loose that any parts would come off during flight...
tomflier |
No matter how loose the rotorhead is, it will not come off during flight? The shafts to the swashplate and the bearings will hold it on tight..
Oops!
I thought you meant the rotor head ball links... The head shouldn't be so loose a breather of aire will let it rock,but it shouldn't be so tight that it will cause extreme shaking. I'm not real familar with the aerohawk though so it may be alittle different... tomflier |
