RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   Aerohawk Tail problem (https://www.rcuniverse.com/forum/electric-rc-helis-167/2029774-aerohawk-tail-problem.html)
mattsh 07-27-2004 09:06 PM
Hi,
I have an aerohawk and love it, but am having a slight problem. I have the trim all the way to the right on the rotor, but it still wants to rotate slightly and I have to keep my hand on the control on the opposite direction, is there anyway I can trim it up more? The controller is at the end, as far as it will go =\
astvga 07-27-2004 09:09 PM
RE: Aerohawk Tail problem
there should be a proportional knob on the reciever, turn that besides the trim
mattsh 07-27-2004 09:11 PM
I see 2 knobs on the receiver one says 204 and one says 103... ahh I'm so glad the manual was so clear to state which was which =) Any idea off hand?... sadly looks like I'll have to break the "shrink wrap" around holding the receiver in place
SMaric 07-28-2004 02:34 AM
If I remember right (do a search to double check - it's been posted before) the pot near the front of the heli is the Gyro sensitivity, the other is the Tail gain control
Be careful when adjusting these pots - they have an end stop which you can break
Make sure you know the original position, before you adjust them
Turning the pot clockwise increases the gain
You don't need to remove all of the shrink-wrap, just use a sharp blade to cut a flap over the pot
zeevro 07-28-2004 10:11 AM
ORIGINAL: SMaric
Yes you remember right......
mattsh 07-28-2004 10:15 AM
Ok, so to make sure about this.
Rotating the rotor control screw will adjust where it 0s in at?
Now what about what someone else said about when you power the receiver on it 0s in on the values it's getting from the transmitter?
zeevro 07-29-2004 06:15 AM
It's very simple:
If the nose goes left spin the mixer gain pot clockwise.
If the nose goes right, spin it counter-clockwise.
mattsh 07-29-2004 06:24 AM
Thanks! It's hovering like a charm now :)
