RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   tail-in practice is straight ? (https://www.rcuniverse.com/forum/electric-rc-helis-167/2250623-tail-practice-straight.html)
mz123 10-13-2004 12:06 PM
Hi,
Im practicing in doing tail-in with my heli on the ground.
however when he moves on the ground (when im increasing the speed) it moves 45 degrees forward and left.
I can follow him and control him however I was wonder if its supposed to be like that(and when its up in the air I can control to stop him?) or it means I have something i need to tune more ? if yes what can it be ?
I found it usefull to start the heli when the thurtoll is abit open , this makes the tail start spinning with the big rotor and I overcome problems of tail spinning around heli (with abit trimming).
thanks
camra88 10-13-2004 07:54 PM
RE: tail-in practice is straight ?
What heli are you using? If its a micro, then i wouldnt be too concerned--micros tend to do that. Try and get it steady the best you can with the trims. Once you get it a couple feet off the ground, you will be out of the "ground effect" and should get a more stable flight. You will just have to compensate with the cyclic stick in order to keep it from going forward and left.
mz123 10-14-2004 04:03 AM
thanks!
im using aerohawk , its micro electric.
