Need a QUICK answer!
Hey i need to quickly place a order and i want to make sure that my part will work with my heli. I own a aerohawk ( skylark ) and i am upgrading to a high authority 7.2 volt tail modor. I need to know if this will work with a 7 cell 700 maH battery pack and if it will mount to the aerohawks tail bracket. Sorry for such a dumb question.
RE: Need a QUICK answer!
The 7.2 tail motor has the same mounting holes as the stock motors. The 7.2v is mostly used for lipo's that run 8.4v or 11.1. It should work with your 7c pack.... uh 8.4v so yes, it won't burn out like the stock motors tend to and will have the power to run it, although with a direct drive setup, the 700mah battery won't last as long as it did with the stock setup
thankyou
| All times are GMT -8. The time now is 03:47 PM. |
