piccolo pro interference???need help!!
Since I have commented in another one post, my piccolo does like an interference, then I put a video (if pop up the volume is heard when it happens perfectly) see if some happens an idea to him...
consumption of the variador Phoenix 10 with haker b20 -1500 kokam-servos hi-tec. I have discarded since before with picoboard and the 400 is the same problem. I have position a diode to lower the tension in the motor of tail-I can prove to clear it connectors of baterys --- before with other but great also me towards but I will change interference to it to the receiver -- I put photo of the antenna to see it... I can prove to put a spcm receiver to him .never me has done it in stationary, always in transfering... I am worry with this since heli flies very well but in someone moment .....!!!!!! any idea? the video of interference: http://www.lagralla.info/interferencia.wmv another one inverted: http://www.lagralla.info/pro.wmv a phot of antenna: http://www.lagralla.info/antena.jpg sorry for my bad english!!! Thanks!! and god flys!! |
RE: piccolo pro interference???need help!!
You have current limiting disabled on phoenix ten?
you have tried smaller pinion on motor?. |
have a 8t pignon , and 7,2 cutoff,
in not correct this config? thanks! |
8 tooth pinion ok, if you run 3 cells better to put cut of at 9.v you will notice the head speed decay before you get to this on 3 cell.
On "current limiting" you set to "diasble' as long as your chopper not over geared then you ok and you not want your chopper to fall from sky right! if a problem, maybe better to catch fire and try to land it!then put out fire. i fly with current limit on disable with no problem . |
| All times are GMT -8. The time now is 11:17 PM. |
