Airtech Bladerunner Help
I just got an Airtech Bladerunner today and have run about 4 battery cycles through it. It takes a good 20-25 minutes to charge, but I only get 30-45 second flight times, then it dosn't even have enough power to lift up off the ground 6 inches. Any ideas of why? Any help would be appreciated.
RE: Airtech Bladerunner Help
Could be the battery is no good. Can you put a volt meter on it after charging it to see if it's charging?
Could also be the motors are getting too hot. If you are brave cut the canopy off and see if it flies longer without it, it's heavy and doesn't allow any airflow over the motors. Are all the blades intact? Even one blade bent or broken will not let it fly long. |
| All times are GMT -8. The time now is 09:22 PM. |
