RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   Sensitive collective (https://www.rcuniverse.com/forum/electric-rc-helis-167/3578739-sensitive-collective.html)
irishairwolf 11-22-2005 09:21 PM
Anybody know how i should adjust ??
The collective at mid stick is very sensitive on my honeybee cp2 any idea's ???
jh4db536 11-22-2005 10:37 PM
RE: Sensitive collective
adjust the pitch curve
if you have a 3 pt then too bad...that's what you get for going cheap.
deves 11-23-2005 09:41 AM
Try moving the three servo connections in 2 or 3 holes on the servo arms. you may need to heat the metal a little with a lighter to get through the holes. This will reduce your throws and thus reduce the sensitivity.
Dave
wfo 11-23-2005 10:13 AM
Reduce the length of the links that you would adjust the tracking with, this will make collective come in later.
