RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   T-Rex Setup (https://www.rcuniverse.com/forum/electric-rc-helis-167/3671728-t-rex-setup.html)
Shortymet55 12-19-2005 08:54 PM
T-Rex Setup
I have posted alot tonight, looking for a nice T-Rex Setup.
This is what I came up with. If you think i should chance something please tell me. This will be only my second heli.
Helicopter- T-rex CDE- $163.20
Motor- 420LF (3200KV)- $45.36
Gear- 10 Tooth 2.0 Bore- $3.99
ESC- Align 35A Brushless ESC(Governer Mode)- $62.16
Gyro- GY401- $139.95
Radio- Futaba 7CH- $169.99
Receiver- Futaba R156F- $59.99
Crystal- Futaba Receiver- $12.99
Servos- Futaba S3103 (3)- $72.47
Servo- Futaba S9650- $59.99
Battery- Thunder Power (TP2100-3S)- $72.95
Charger- Hobbico Charger- $49.99
If there is anyway the total price can go down, please tell me. The total now is $963.03. Thats alittle steep for me.
KiwiSpinner 12-19-2005 11:19 PM
RE: T-Rex Setup
Have you checked the packages here?
http://www.helihobby.com/html/trex_helicopter.html
All come in under 900! All similar gear, and the SE model is the one at 899
boostcrzy 12-19-2005 11:34 PM
RE: T-Rex Setup
Call John over at www.ReadyHeli.com and tell him Jack sent you...he will give you a GREAT deal on a RTF T-REX combo...trust me...readyheli can meet and BEAT any price you find...and the heli's are all setup in-house by the team pilot Chris....ive seen these helis fly in person and they do fly PERFECT....definately great folks to deal with.....
Jack
Shortymet55 12-20-2005 09:41 AM
RE: T-Rex Setup
Is the Hitec Eclipse 7-Channel QPCM a good radio, with all required mixing capabilities? If I get it can I use a Futaba 6Channel PCM receiver with it?
ramkitty 12-20-2005 12:16 PM
RE: T-Rex Setup
NO, i believe the hitec radio eclipse/optic only support qpcm which is a propriatary pcm modulation
Shortymet55 12-20-2005 12:43 PM
RE: T-Rex Setup
Umm, well where i was looking(helihobby), I costomize the T-rex. Its has the Hitec Eclipse 7 transmitter only with Spectra Modules as a choice of radio. Then I need a reciever. There are 3 choices: Hitec Futaba Shift 6 Channel Dual Shift Receiver, Hitec JR Shift 6 Channel Dual Shift Receiver, and Futaba Receiver R146iP PCM 72MHz. None of those are qpcm. Does this mean either i get a reciever, but never use it, or dont get the radio at all?
Shortymet55 12-20-2005 12:47 PM
RE: T-Rex Setup
I guess I will put no transmitter, then get a Futaba 7CHP
exeter_acres 12-20-2005 12:58 PM
RE: T-Rex Setup
PCM is not cross brand...
while PPM allows mixing and matching (assuming you choose the correct shift)
PCM at this point as no standard so you have the use the same brand Rx as your TX
ramkitty 12-20-2005 02:14 PM
RE: T-Rex Setup
i just bought the optic 6 tx with spectra module, it was on there sale page, 189 i think and included the hitec qpcm supreme rx (which i am not using) but i can either ebay it or keep it for a future project, i chose to go for the electron 6 rx, it is pretty small 2/3 size of the supreme
Shortymet55 12-20-2005 05:45 PM
RE: T-Rex Setup
Ok, well a Futaba 7CHP will work with a Futaba Receiver R146iP PCM 72MHz then. Correct?
ptgarcia 12-20-2005 07:17 PM
RE: T-Rex Setup
Yep. And I would shop somewhere other than Helihobby. They owe me money on a return and they don't want to pay. I'm done ordering from them.
freez 12-20-2005 08:19 PM
RE: T-Rex Setup
I had mine built and got everything for it from modefo's , excellent guys to deal with , www.modefos.com
sjw985 12-21-2005 08:15 AM
RE: T-Rex Setup
ORIGINAL: freez
Ummm... I'm sure that was just a typo, but that's not a helicopter website. Warning to those in the office - don't click.
exeter_acres 12-21-2005 08:22 AM
RE: T-Rex Setup
Whoooops!:D
but thanks for the links![:@]
I bought my Trex from Jeremy at Rchover.com
he has good stuff over there and has great service
Shortymet55 12-21-2005 09:26 AM
RE: T-Rex Setup
This is way more expensive than I thought. Im going to hold off on another heli for a long while.
consultjdm 01-03-2006 06:46 PM
RE: T-Rex Setup
You can get the receiver at Hobby People for $100.
I have one on my Shogun and it works?
I'm putting one on my Logo 10
consultjdm 01-03-2006 06:47 PM
RE: T-Rex Setup
I mean I have The QCPM Receiver in case you were not sure
