Is this a good setup?
LXM086 HeliMax Heli Pitch Gauge w/Pouch
1 24.99 LXKHJ7 HeliMax Heli Blade Balancer 1 22.99 LXM060 HeliMax Tracking Tape 1 1.99 LXGBG4 Traxxas Velcro (3) 1 2.39 LXCMA6 Futaba Gyro Foam Mounting Pads 30x30mm (3) 1 4.49 LXPR35 Hobbico Soldering Iron 30 Watt 1 4.99 LXFS75 Sta-Brite Silver Solder 3/64" 1/2 oz. 1 7.59 LXKX39 W.S. Deans 2-Pin Ultra Plug 2 3.09 LXGDU8 W.S. Deans Female Ultra Plug (2) Qty Discount Available 1 2.69 LXJDF9 Futaba 9CHPS 9-Channel Synthesized Tx/Rx 72MHz Mode 2 1 499.99 LXM088 HeliMax Ball Link Pliers 1 27.99 LM1765 Futaba S3110 Micro High Torq Servo 7.7g NOTE:"Price Each" reflects price for each quantity of 3 to be shipped 3 41.97 LXGVS1 Castle Creations Phoenix-35 Brushless Motor Control 1 84.99 LXGVR8 Castle Creations Castle Link Programming Kit 1 21.99 LXJRW0 Futaba R146iP PCM 72MHz Single Conversion w/o Crystal 1 79.99 LXBFL240 Futaba FM RX XTL 72H High 40 72590 1 12.99 LXL430 Hobbico Latex Foam Rubber 1/4" Qty Discount Available 1 2.99 LXFZP2 Futaba GY401 Gyro w/S9254 Digital Servo 1 219.99 LXD832 Dubro Dura-Collars 3/32" (4) 1 1.39 Combined: $1072.58 New T-REX 450SE(CDE) Kit/Silver +New 430L3550+35G ESC $529.90 $ 529.90 Ferrite Ring $1.90 $ 1.90 TP 2100 pro Lites 3s $70.95 $ 141.90 HR-Poly LiPo Battery Monitor and Voltage Logger $31.90 $ 31.90 Cen-Tec 6" Digital Caliper $32.99 $ 32.99 Micro Digital Tach $27.95 $ 27.95 ALIGN Micro Pitch Gauge $14.30 $ 14.30 7 Function Digital Multimeter $8.90 $ 8.90 HS1006 ( 2 Flybar Rods ) x2 $4.60 $ 9.20 HS1011-3 TRex main shaft and collar set $8.20 $ 8.20 HS1119 Linkage Rod Set/SE,CF $3.90 $ 3.90 THUNDER POWER TP-205 CELL BALANCER $59.95 $ 59.95 Sub Total $ 870.99 |
RE: Is this a good setup?
Most of it looks pretty good IMO. Why get 2 pitch gauges unless you need the standard size for a larger heli? The 401 gyro is great, but the 9254 is a standard size servo and much too large for the Rex. You'll want to get the Futaba 9650 servo for the tail rotor to go with the 401 gyro.
so the micro will work for both the tail blades and the main blades?
you probally want to get something a bit faster for your tail than what your using on the cyclic. You don't need as much torque for tail servos just more speed to keep the tail in one place.
S9254
SPECS: Speed: 0.06 sec/60 deg @ 4.8V Torque: 47.2 oz-in @ 4.8V Length: 1.6" (41mm) Width: .8" (20mm) Height: 1.4" (36mm) Weigth: 1.7 oz (49g) Power Supply: 4.8V (Futaba does NOT recommend using 6V) s9650 SPECS: Length: 43mm between centers of side mounting holes 35.5mm servo body length 42.5mm between the centers of standard mounting holes Width: 15mm Height: 28.6mm Weight: 0.9oz (26g) SPEED: .14 sec/60degrees @ 4.8V .11 sec/60degrees @ 6.0V TORQUE: 3.6 kg-cm @ 4.8V (50 oz-in @ 4.8V) 4.5 kg-cm @ 6.0V (62.5 oz-in @ 6.0V) [sm=confused.gif] im lost now |
| All times are GMT -8. The time now is 10:06 AM. |
