battery question
I have 2 lipo battery packs the 1st is a 7.4v 700mah the second is a 7.4v 1000mah can I use the 1000mah battery pack in place of the 700mah battery pack? they both have the same connectors. The 700mah battery pack came with the helicopter. I have the charger for the 1000mah pack
RE: battery question
If a bit more weight is not going to cause a problem, then the 1000mAh pack sould be a good substitution for the 700mAh pack of the same voltage.
What are you using them on? |
Well was a good idea till I tried to fit the battery into the battery holder .... won't fit
It's a DH 9081... I know it's just a simple cheap helicopter |
| All times are GMT -8. The time now is 02:47 AM. |
