Tracking
What does it do to a heli as far as hovering when your tracking is way off
RE: Tracking
vibrations (which cause unnecessary wear on your components) and erratic flight.
RE: Tracking
It is a heli max mx 400 and I have heard that the blades are crap and some times can not be tracked so,I was thinking about buying a set of align blade for the trex but they are longer what pinion should I chage to in order to run them and can I even do this
RE: Tracking
I think you can use the align 305mm blades for that.
See this link. http://www.fxaeromodels.com/product_...oducts_id=2204 I did a quick search and found that, I'm not reccomending you buy from them (not saying don't either, I have never heard of the company). I've had my tracking be out to the point where it makes the heli tough to control and sounds bad, can't fly that way for any length of time without causing problems. |
| All times are GMT -8. The time now is 02:34 PM. |
