servo prob
when i plug in my battery to my heli he pitch servo will shoot up at a 90degree angle how do i fix that .....
also when i move the aleron on my tx the my elevator will move? |
RE: servo prob
What heli do you have??? You should check the manual first to see if all the switches are in the right positions and als remember to switch on the Tx first then plug in the heli... |
RE: servo prob
did you bind it properly? did you center the arms at 90 degrees with throttle at midstick?
| All times are GMT -8. The time now is 09:00 PM. |
