Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
64mm motors for 4s
Old 04-02-2011, 12:41 PM
mobaddawg
mobaddawg's Avatar
Default 64mm motors for 4s
Hi,
I am looking for a motor that is for 64mm edf units and can run on a 4s battery. I put a 60 amp esc in it with a 4s 2200 mah 20c battery and a 5000kv motor and fried the motor within 30 seconds. I want to put a exceed rc 4800kv motor in it. I have seen this setup used before so I was thinking it might work. But another thing, do I really need to get that motor? I have a old FMS motor that is 4100kv and I run it on a 3s 2200 25c. Any help is much appreciated! Thanks!
Old 04-02-2011, 01:20 PM
Extreme_RC
Extreme_RC's Avatar
Default RE: 64mm motors for 4s
Kv is way too high for 4 cells in a chinese style 64mm fan, you are better off with 3500-3800Kv and it needs to be a solid motor. Our 2445 series inrunner motor runs in the GWS 64mm fan on 4 cells and puts out 1100g thrust at around 38 amps with 2200mah packs, very efficient, less amp draw than euqivalent outrunners. If you want something with more grunt we produce a custom 64mm fan with GRP or CNCalloy housing and machined Wemotec rotor, 1.4kg thrust on 4s at 62A and almost 2kg thrust on 6s at67A!
Old 04-04-2011, 12:17 PM
4stripes
This Freewing motor is the highest KV motor I would suggest for 4S. Freewing has started using this in their updated version SU-34 twin 64mm plane (used to be 3500kv now 3800kv).
http://www.hobbyking.com/hobbyking/s...dProduct=11161
Just make sure you locktite the set screws located in the shaped motor end.
Old 04-04-2011, 01:34 PM
mobaddawg
mobaddawg's Avatar
Thank you fellow Canadian.
Old 04-04-2011, 05:28 PM
Extreme_RC
Extreme_RC's Avatar
The freewing are good motors, just pull more amps to do the same rpm as good inrunners.
Old 04-05-2011, 02:18 AM
jesses151
jesses151's Avatar
I personally would check with Don http://donsrc.com/cart/index.php?act=viewCat&catId=3
He's great to deal with and if you e-mail him he actually gets back with you within a day.
-Jesse
