VOLTZ lipos???
has anybody tried voltz lipos on an airplane? i am currently using a 30c 6s 4500maH on a 90mm jet, a friend gave me a 45c 6s 4500maH to try out. how will it affect the performance?
TX
Ihave never tried Voltz. Do you have a data logging ESC? Run both either on the ground or in the air and then compare the logs to see what differences there are. Doing a ground run will allow you to verify that all the cells are healthy before your flight.
Eric
Eric
