newbie question...
<hr size="1" style="color: rgb(167, 167, 167); background-color: rgb(167, 167, 167);" />
What happens if i run (the listed specs below) on a 4s 2200mAH instead of a recommended 3s lipo on a 60amp ESC???:
Delta-V 480 65mm EDF System, 4800Kv
Key Features
* Designed for high current 3S Li-Po batteries capable of up to 60A batteries
* Ideal high current 3S option for the E-flite® F-16 DF
* Includes 65mm Fan Unit with installed BL480 Ducted Fan outrunner motor
* High-performance, efficient design EDF
* Injection molded, fiberglass-filled nylon
* Factory-balanced 65mm 6-blade rotor design
* BL480 4800Kv DF Motor is ideal for up to 650 input watts
Overview
This system is the recommended high current 3S choice for E-flite’s F-16 400 DF. The included BL480 Ducted Fan Brushless Motor, 4800Kv (EFLM1555DF) is purpose-built for this Delta-V 480 65mm EDF and together will provide great power 3S performance.
Performance Data (Measured Using BL480 4800Kv Motor)
Static Thrust: 1.6 lb on 3S (11.1V)
RPM: 45,000 on 3S (11.1V)
Watts: 565 on 3S (11.1V)
Current: 56A on 3S (11.1V)
BL480 Ducted Fan Motor Specifications
Kv: 4800 (rpms per volt)
Io: 3.1A @ 10V (no load current)
Ri: .023 ohms (resistance)
Continuous Current: 45A*
Max Burst Current: 58A*
Cells: 3S Li-Po
Brushless ESC: 60A
Delta-V 480 65mm EDF Unit Specifications
Rotor Diameter: 65mm (2.5 in)
Shroud Outer Diameter: 68mm (2.7 in)
Shroud Length: 42mm (1.65 in)
Weight: 30g (1.05 oz)
Overall Weight: 112g (3.95 oz) (motor and EDF unit)
*Data measured using included BL480 DF Brushless Motor
Actually i am not using on an an eflite plane. I intend to use it on another F16. Will it fry my ESC if i use a 4S?
Key Features
Overview
Cells: 3S Li-Po
Brushless ESC: 60A
ESC should be OK, as long as it will handle 4S, but I think the motor will smoke. Also, is there enough room in plane for 4S pack? If you can program a throttle curve or adjust the end point down so you are not running maximum RPM you may be OK.
Hope this helps.Keith
You have the performance numbers for 3s, 56 amps, 565 watts, 45000 rpm! On 4s the motor will TRY to spin that fan at 80640 rpm, your 2200mah pack voltage will sag under load. That load will be much greater than your 60amp esc's rating. Your 4s 2200mah pack will have a hard time maintaining more than 3 volt/cell under this load. Choose a motor with a lower Kv for 4s.
I think 172AMD says it right. With such a high KV rating the motor is going to try and turn faster and when it can't, the excess draw from your battery will be wasted to produce heat. Not good for the motor or ESC.
