Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
Help! How do I re-connect 50mm F-86 motor?
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 06-18-2011, 04:54 AM
52Sabre
Default Help! How do I re-connect 50mm F-86 motor?
Hi fellas! Finally got the guts to try to fly my 50mm F-86 this morning early. Unfortunately I didn't have the CG set right and it did a nose dive. Now I discover the motor is now disconnected. How do I re-connect it? It looks like I need to pull the motor to re-connect it but the motor appears glued in place? The wings are epoxied on so I can't get at it from there. Solution(s)? thanks.
Old 07-25-2011, 06:35 AM
whoanelly
Default RE: Help! How do I re-connect 50mm F-86 motor?
you can pull it outits not glued in there very good. just reconnect after you pull it ,mine fit so tight i dont even re-glue back in . your choice.
Old 07-25-2011, 04:30 PM
52Sabre
Mine was glued in pretty good. Took a lot of judicious wiggling for it to break free. Must have had a very thin layer of adhesive. Following other advice now am using double sided poster tape that seems to be working ok.
