what is this model?
what is this model?
I have this Ducted Fan jet (90MM Fan). I am assembling it for a friend. He can't remember what it was called and it has no instructions. He thinks he got it from R2 Hobbies in HK.
Does anyone know what it was called and better still have a construction manual. I have sort of figured out how it goes together, but some instructions would be nice to see the CG position etc.
Has anyone built one and if so how does it fly.
RE: what is this model?
I forget what the name of the model is, but EJF.com used to sell it. It was marketed as a trainer type. Ask for Robert as I'm sure he can help you out. Good Luck!
FB
FB
Thanks Guys,
I have pretty well sorted out how it goes together, but I would like to see how to mount the fan. It is a little bit tricky. it seems the fan is mounted between the two halves of the housing. I have found a build sequence for the 70mm version. The 70 mm version comes with the fan installed so it was not a lot of help.
I will contact the EJF and see if they can help.
Regards
Regards
