Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
BVM EVF fan for Tam Jets F-16
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 08-07-2011, 12:19 PM
rcand
Default BVM EVF fan for Tam Jets F-16
Does anyone know if the BVM EVF fan will fit in the TAM Jets electric F-16?
Old 08-09-2011, 05:59 AM
Avaiojet
Default RE: BVM EVF fan for Tam Jets F-16
Won't knowing the measurements of both yield that information?
What if someone says "yes" and they are wrong?
Do you already have the BVM EVF fan?
What does EVF stand for?
Old 08-09-2011, 10:55 AM
vasek
vasek's Avatar
ORIGINAL: Avaiojet
Electric VioFan
Old 08-09-2011, 04:20 PM
rcand
ORIGINAL: Avaiojet
What if someone says ''yes'' and they are wrong?
Good point, if I had the exact measurements, say both in metric, than I would have the answer and since there is some room for error in what a manufacturer claims in some measurements and since the information from someone who ACTUALLY installed a BVM Elevtric VioFan, EVF, into the plane in question would be considered more valuable than simply taking measurements from some website or piece of paper, especially considering that the installation could show some issues that may require adjustments in mounting, etc, hence the reason I developed this post.
Old 08-09-2011, 09:40 PM
skyhawknut
The 120mm one will fit as the EVF is 120mm.
Tam has ducting.
Old 08-10-2011, 10:36 AM
Avaiojet
What?
You are saying you don't have confidence in the BVM measurements?
I thought he had it down pat?
If that's the case, and it clearly is, I can see why you would want the advice from someone who has avtually made the conversion.
Also, they could guide you through it.
Old 08-10-2011, 11:44 AM
rvnrcer
Just measured my EVF. Outer diameter is just under 124.5 mm. To the outer ribs it is 128 mm. Centers between the mounting lugs are 140 mm. Intake inner diameter would need to be 125mm to mate up to EVF without any modifications. I dont know any dimensions on the F-16, but maybe this will help.
Keith
Old 08-10-2011, 03:16 PM
rcand
ORIGINAL: skyhawknut
Tam has ducting.
thanks, I sent an e-mail to TAM weeks ago but he never replied. I thought maybe he did not like the idea of not using his fan and motor for his kit. I like the F-16 and have the BVM 12S stuff
Old 08-11-2011, 02:47 PM
rcand
ORIGINAL: rvnrcer
Keith
thanks
