Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
 Mirage 4000 Famous / HK Personnal Speed record : >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 10-02-2011, 08:41 AM
Default Mirage 4000 Famous / HK Personnal Speed record :
Hi pilots,
<div>Just to share with you my personnal speed record of today on my Mirage 4000 from Hobby King, tuned with E-Flite component (motor, ESC, EDF from Parkzone Habu...) and a 3300 mAh lipo.</div><div></div><div>My top speed was 109,32 miles/h (175,9 km/h) checked with Holux M-1200E GPS Data logger in Paris. No wind.</div><div></div><div>You can watch my onboard video :
www.youtube.com/watch?v=-3aIihBHXSg
What is your max speed with that kind of jet ?
Have a good day,
John Wax</div>
Old 10-06-2011, 01:36 PM
ACES&8s's Avatar
Default RE: Mirage 4000 Famous / HK Personnal Speed record :
Bravo...6 blade fan?
4 cell good battery...3200kv motor?
The reason I ask is this: Would you try a Cyclone 3300, 3700, or 4100 kv outrunner on the 4 cell and Delta V 15 fan unit? My Rafale by HET has 2 WemoTec Minifan pro, with 4 cell and 4100kv motors. Power is 1400 watt, and the fan is 5 blade.
I don't know what sort of thrust I get...the aircraft is 5.25 lbs. or about 2.4 kilos. Have not flown it yet.
I cannot understand why my setups are more kv than others in 70mm fans. Is it that I'm pushing the limits? The current draw is 86 amps.
I have other 70mm (HET 6904, generic Wemo, WM400 (pusher)) with setups like 6 cell/2500kv motors (others are using 1850kv on 6 cell) My units are stable and put off lots of power...1400 to 1600 watts per fan. I still cannot measure thrust, and static thrust is dangerous anyway...it seems best to run the fans at full rpm while moving...
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
