Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
 Hobby King Gulfstream G-500 >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 12-16-2011, 10:23 AM
Jeanskydive's Avatar
Default Hobby King Gulfstream G-500
Hi Scale fans,Start is new Gulfstream, I did the mod., for the the windows by reducing a bit in size , look more scale like, I use sheet of plastic and paint one side with nit-shades, I cut the windows plastic a bit over size ,on one sideI apply a white plastic film, and silicon from the inside of the fuselage, easy no mess and easy with plenty of space to work , this made a big difference on the first look. Cheers
ID:	1700772   Click image for larger version
ID:	1700773   Click image for larger version
ID:	1700774   Click image for larger version
ID:	1700775   Click image for larger version
ID:	1700776   Click image for larger version
ID:	1700777   Click image for larger version
ID:	1700778   Click image for larger version
ID:	1700780   Click image for larger version
ID:	1700781   Click image for larger version
ID:	1700782   Click image for larger version
Old 12-16-2011, 01:41 PM
Greg Covey's Avatar
Default RE: Hobby King Gulfstream G-500
Very nice modification! The windows look much better.
Good luck on your G-500 build.
Old 12-16-2011, 05:43 PM
Hi Greg , You have a verry nice web hangar there , easy to check the set-up of each the model , give us a verry good for idea for set-up. Cheers
Old 12-16-2011, 05:47 PM
The Hitec HS-125 fit perfect in the stab., srew flat on the bottom, JB Weld glue for the control horn Cheers
ID:	1700966   Click image for larger version
ID:	1700967   Click image for larger version
ID:	1700968   Click image for larger version
ID:	1700969   Click image for larger version
ID:	1700970   Click image for larger version
ID:	1700971   Click image for larger version
ID:	1700972   Click image for larger version
Old 12-18-2011, 01:22 PM
Larry Dudeck's Avatar
Huge improvement on the windows.
What are you going to power her with?
Old 12-19-2011, 12:12 AM
Yes Sir the windows made a big difference in scale like , probadly a Typhoon 600-43 with Het fans for power . Cheers
ID:	1702032   Click image for larger version
ID:	1702033   Click image for larger version
Old 12-19-2011, 06:20 PM
Work in the nose gear a bit today with instal the cables stering, and the maple blocks and the gear plate fearing . Cheers [link]http://youtu.be/t8YDRPYpHJU[/link]
ID:	1702319   Click image for larger version
ID:	1702320   Click image for larger version
ID:	1702321   Click image for larger version
ID:	1702322   Click image for larger version
ID:	1702323   Click image for larger version
ID:	1702324   Click image for larger version
ID:	1702325   Click image for larger version
ID:	1702327   Click image for larger version
ID:	1702328   Click image for larger version
ID:	1702329   Click image for larger version
Old 12-19-2011, 08:36 PM
Looking VERY nice!
Old 12-21-2011, 02:56 PM
Thanks Gary, did some improvement in the main gear today with is little wheel door., the nose is complet with zinchromate primer ready to paint finish. Cheers Video clip [link]http://youtu.be/Y9Ww1WS7eak[/link]main gear retract.
ID:	1703284   Click image for larger version
ID:	1703285   Click image for larger version
ID:	1703286   Click image for larger version
ID:	1703287   Click image for larger version
ID:	1703288   Click image for larger version
ID:	1703289   Click image for larger version
ID:	1703290   Click image for larger version
ID:	1703292   Click image for larger version
ID:	1703293   Click image for larger version
ID:	1703294   Click image for larger version
Old 12-29-2011, 12:08 AM
Wires cable and motors installation conectors etc., etc., Cheers
ID:	1706333   Click image for larger version
ID:	1706334   Click image for larger version
ID:	1706335   Click image for larger version
ID:	1706336   Click image for larger version
ID:	1706337   Click image for larger version
Old 12-31-2011, 05:25 PM
Retract installation complete, the T-45 retract gear fit just perfect for this model , do not need any modification, fitb just in place., Small video clip. retract gear. Cheers [link]http://youtu.be/_BL0h_9vKQM[/link]
ID:	1707890   Click image for larger version
Old 01-01-2012, 02:51 PM
My Feedback: (33)
Nice job! Are the wings and stabs painted plastic covering? Please keep us abreast of progress and flight report Thanks for sharing.
Old 01-01-2012, 09:00 PM
Yes Myers , the wing epoxy paint over plastic film covering, gelcoating also for the fuselage, the door line done, glue those carbone tube with JBwel in place, stab tackin into the fin, also I change the magnet for stronger force one, nose gear installation complete. Cheers
ID:	1708377   Click image for larger version
ID:	1708378   Click image for larger version
ID:	1708379   Click image for larger version
ID:	1708380   Click image for larger version
ID:	1708381   Click image for larger version
ID:	1708382   Click image for larger version
ID:	1708383   Click image for larger version
ID:	1708385   Click image for larger version
ID:	1708386   Click image for larger version
ID:	1708387   Click image for larger version
Old 01-06-2012, 09:48 AM
Motor installation completed with test run for the Astro 25 -4t, HET 90 mm fan, with 6S-5000 LiPo 63 AMPS, 1,400 watts, each,. (2,800 both) will bee smooth flying with this motors, probably need more efficient one for this model. Cheers
ID:	1710388   Click image for larger version
ID:	1710389   Click image for larger version
ID:	1710390   Click image for larger version
ID:	1710391   Click image for larger version
ID:	1710392   Click image for larger version
ID:	1710393   Click image for larger version
ID:	1710394   Click image for larger version
ID:	1710396   Click image for larger version
Old 01-17-2012, 06:40 PM
My Feedback: (34)
tailskid's Avatar
very well done! Keep working.....
Old 01-28-2012, 10:30 AM
The Gulfstream complete , maiden in spring season, Cheers.
ID:	1720191   Click image for larger version
ID:	1720192   Click image for larger version
ID:	1720193   Click image for larger version
ID:	1720194   Click image for larger version
ID:	1720195   Click image for larger version
ID:	1720196   Click image for larger version
ID:	1720197   Click image for larger version
ID:	1720199   Click image for larger version
ID:	1720200   Click image for larger version
ID:	1720201   Click image for larger version
Old 05-11-2012, 12:40 PM
rgburrill's Avatar
ORIGINAL: Jeanskydive
It's spring! How about some videos?
BTW, great work.
Old 12-19-2014, 07:35 PM
Hello, I just bought one of these jets from HK and it did not come with a manual. Can you tell me where the CG is located please? Thank you very much! BTW great job on yours.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
