Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
 F-18 Foam Build Jepe F-18 Hornet >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 12-19-2011, 06:29 AM
ACES&8s's Avatar
Default F-18 Foam Build Jepe F-18 Hornet
I restarted my work on the undercarriage, and have some photos. A vid will be on youtube soon.
Old 12-19-2011, 06:42 AM
ACES&8s's Avatar
Default RE: F-18 Foam Build Jepe F-18 Hornet
http://www.youtube.com/watch?v=Pdzs0...1&feature=plcp[link]http://www.youtube.com/watch?v=Pdzs0kz6SBU&list=UUET12AJ1Ogn8GiCg3lysZHw& index=1&feature=plcp[/link]
Old 12-20-2011, 04:35 AM
ACES&8s's Avatar
I've rough cut carbon fiber tube and knees from a smaller set of l/g, applying all of it to near-scale mains. 1/8 (3.2mm) music wire axles fit into the lower leg sections, and will be centered on dowel, self-pinning, anchored into the knee stubs. Springs allow the full travel when the model is at rest on the Landing Gear. I still have to length both upper and lower strut sections, to fit the height requirements. The l/g has to fit up into the fuse, so that's my main consideration, aside from setting the aircraft level on all the landing gear. I have no worries over large l/g openings/doors. The foam will hinge and the closure will have magnets to assist. Just simple cross-fitting pull cable to close the doors, spring-hinges to hold them open. Gear doors not scale.
ID:	1702454   Click image for larger version
ID:	1702455   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
