Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
Reload this Page >
Shuttler F-15 70mm CG
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 04-02-2012, 11:40 AM
goirish
goirish's Avatar
Default Shuttler F-15 70mm CG
I have a Shuttler F-15 70mm ducted fan. Span is 1100mm, Wingspan 740mm. Flying weight 690g. Anyone have any idea where I would balance the plane at. I've look closely at the manual and it does not say. All is says is "if the plane flies like a wave after takeoff then the nose it too light Or, if the plane rises slowly or flies parallelly after it takes offs, it indicates that the nose is too heavy" Heck of way to adjust the CG. I like that word PARALLELLY . Any help would be appreciated.
Moderators if this is posted in the wrong forum please delete.
Title change only...
Old 04-02-2012, 03:00 PM
Greg Covey
Greg Covey's Avatar
Default RE: Shuttler F-15 70mm CG
The Shuttler F-15 is a few years old but the recommended CG seems to be here in the image below on the red lines...about 225mm measured from the back of the main wing. The red arrow in the back shows where to add the weight, if needed. Note the long wire on the left wing for the 72MHz receiver.
Good luck!
