Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
habu 32 rec battery
Old 04-10-2012, 11:10 AM
My Feedback: (9)
Default habu 32 rec battery
hi,i just bought a used habu 32 with a hacker esc,which has no bec,i bought a 4.8 volt 2000 nimh for it,will that be enouph,should i have gone with a 6 volt,ive always had bec,so i dont know where to plug it into the rec, can i plug it into the bind port and should i use a switch,thanks
Old 04-10-2012, 01:22 PM
Greg Covey's Avatar
Default RE: habu 32 rec battery
That pack will work fine. You can plug it into any spare channel, including the bind port.
Since my review on the Habu 32, I have switched to using this [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYAS7&P=ML]1100mAh[/link] Hobbico LiFeSource LiFe 6.6V (10C) receiver pack. I plug both black connectors directly into the receiver for redundancy. No switch is used. The pack weighs about 3.3oz and I cut off the Deans Ultra cable.
Old 04-11-2012, 04:35 AM
My Feedback: (9)
so greg how do you shut it off, (sorry,i never had to do this ,)thanks,oh and i ended up getting a 2 cell 2500 lipo,will that plug right in,or do i need a regulator thanks
Old 04-11-2012, 06:32 AM
Greg Covey's Avatar
You shut it off the same way you disconnect the DF power...pull the plugs.
When using a 2s LiPo pack, you'll need a regulator...hence the advantage of LiFe (aka A123) cells. With LiFe cells and no On/Off switch, you eliminate several common failure areas in R/C planes. It also helps to keep the Spektrum receiver resetting due to current spikes on the line.
Old 04-13-2012, 05:48 AM
You can unplug it or get a switch, unplugging it will put stress on the connector after time. Back in the glow only days, all radios came with a switch for the NiCd battery, you can still get them. 7.4v will usually be too much for standard servos, so I've used a MPI voltage regulator, this is the one I've used [link=http://www.tamjets.com/original/product_info.php?manufacturers_id=22&products_id=3 36]MPI Voltage regulator[/link] and they also make this one with a switch [link=http://www.tamjets.com/original/product_info.php?manufacturers_id=22&products_id=3 37]MPI w/ switch[/link]
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
