Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
 Tail Tube for 90mm ducted fan >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 06-13-2012, 09:33 AM
Default Tail Tube for 90mm ducted fan
I have a friend looking for a tail tube (exhaust) for a 90mm ducted fan Ideally it would taper from 90 to 80mm and be around 12in long.
Is this something we can guy somewhere or are we going to have to fabricate it? If we can purchase, can you please name a supplier?
Thanks for your responses.
Old 06-13-2012, 12:44 PM
Moderator
AMA 74894's Avatar
Default RE: Tail Tube for 90mm ducted fan
http://www.officemax.com/office-supp...oduct-ARS25667
make one end 95mm, the other end make 85mm (5 mm for overlap)
HobbyKing also has the material.. for a whopping $1.99
http://www.hobbyking.com/hobbyking/s...C_1_Metre.html
Not to plug HK or anything, (I was also looking for specific instructions) the 4th post down has step by step instructions...
http://www.hobbyking.com/hobbyking/f....asp?TID=22007
hope it helps!
Old 06-13-2012, 01:44 PM
My Feedback: (9)
juanjulian's Avatar
The taper of 80-85 mm is to big.
Go from 72 to 75 mm
Cheers,
Juan
Old 06-14-2012, 02:28 AM
So what you are really saying is that it can be flown without an exhaust tube.
Old 06-14-2012, 05:33 AM
Moderator
AMA 74894's Avatar
it should be able to be flown without it. the thrust tube is something typically used to gain better performance from the EDF unit, but in some cases (typically for bigger / more complicated jets) it can be used to keep things (like elevator servo leads) from causing turbulence in the exhaust.
TYPICALLY, (for an EDF) the thrust tube is optional.
what airplane we talking about?
Old 06-15-2012, 05:58 AM
Red Hawk 90mm Ducted fan Jet.
Old 06-20-2012, 05:51 PM
speed is life's Avatar
ORIGINAL: AMA 74894
.............TYPICALLY, (for an EDF) the thrust tube is optional........
Not true, a "typical" EDF will not perform well at all without a thrust tube, unless you are talking about little depron profile types.
Tubes can (as mentioned above) be simply made using rolled Mylar drafting film. You want the exhaust to be about 85% to as small as 80% of Fan Swept Area.
Good WAG for a 90mm fan is 70-75mm outlet
Mike Warren
www.performance-edf.biz
<br type="_moz" />
Old 06-28-2012, 01:58 PM
My Feedback: (23)
buy yourself some mylar. a roll is nice to have to experiment with
Old 08-03-2012, 01:53 PM
so say you have an 100mm fan then with say 100mm going in to fan what should the out be at end of fusalage ? Neil
Old 08-03-2012, 02:09 PM
ORIGINAL: tinker27
That depends on what fan you have, each is different as to "FSA" ......(Fan Swept Area - area of the circle covered by the blades MINUS the area covered by the outer diameter of the motor holder)
Typically you set the exhaust "area" at 80-90% of "FSA", work backwards from the area to derive the required diameter of the exhaust.
A decent place to start is 85% FSA
This number can also be dependent of how much intake area you actually have to feed the fan,If you had tight intakes then you don't want the exhaust area to be greater than intake area........no matter what the FSA calculation tells you it would require tightening up the exhaust for decent performance.
-Mike
<br type="_moz" />
Old 08-03-2012, 02:23 PM
well im gonna use a stumax 100-45 mm in a AMD hawk so any ideas speed is life ? thanks Neil
Old 08-03-2012, 03:59 PM
ORIGINAL: tinker27
Just measure your fan and do the maths.......or there are online area and circle calculators.
Im out at work or I could measure the 100-45
80mm exhaust will get you close.
The 100-45 will be a nice lighter (but powerful) alternative to the 120-127mm diameter fans
-Mike
<br type="_moz" />
Old 08-04-2012, 10:52 AM
Thanks mike will do , regaurds Neil
Old 01-03-2016, 08:52 AM
Ok, guys, Answer this question for me please..I have a 90 mm ducted fan F-86. When the fan and motor were installed, the installer cracked the thrust tube where the wiring for the motor passes thru it..It was done without much care..What I want to know is if I can smoothe it out and just install a four to six inch section of mylar or whatever is used for thrust tubes, to repair just this area..Just to smooth it out....I can not remove the existing cracked tube...Any better Ideas out there..Thanks, And fire some ideas at me..
Well I fired this jet up and it just blew the thrust tube into pieces and out the tail pipe, so now need to fab and install a new tube....
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
