Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
YF 23 build
Old 10-31-2012, 05:35 PM
unclecrash's Avatar
Default YF 23 build
Here is a link to a build im doing. Its about 6ft. with a 45in. span for twin 90mm fans. Designed by Dfast and the wing by P901P901. It will be a slow build over the winter. Build starts on about page 12 of my blog
http://www.rcgroups.com/forums/member.php?u=44257
Old 11-04-2012, 02:10 PM
unclecrash's Avatar
Default RE: YF 23 build
I worked on the tails today.
ID:	1817563   Click image for larger version
ID:	1817564   Click image for larger version
Old 11-04-2012, 09:44 PM
unclecrash's Avatar
I just got done jigging the tail former up and installing the shafts into. Tails are ready for skins on the other side. Need to find so 1/16 balsa to build the skins.
Old 11-05-2012, 12:31 PM
unclecrash's Avatar
I just got done glueing the rear section to the tail former. I used some milled glass in the epoxy to fill in all the voids around the tail shaft area.
ID:	1817857   Click image for larger version
ID:	1817858   Click image for larger version
Old 11-10-2012, 08:17 AM
My Feedback: (9)
juanjulian's Avatar
This tipe of build are rare here in rcuniverse.
Keep the good work.
Fallowing.
Cheers
Juan<br type="_moz" />
Old 11-11-2012, 06:28 PM
unclecrash's Avatar
Thanks Juan, not too many people scratch building these days.
Old 12-10-2012, 12:27 AM
unclecrash's Avatar
I been chipping away at it. Here is a couple pics.
ID:	1828451   Click image for larger version
ID:	1828452   Click image for larger version
ID:	1828453   Click image for larger version
Old 01-20-2013, 01:28 PM
ACES&8s's Avatar
twin 90mm fans..what sort you going to use? High power setup?
Old 01-21-2013, 07:36 PM
yeah,good info,<span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);">Tails are ready for skins on the other side. Need to find so 1/16 balsa to build the skins.thanks</span><font face="Verdana, Arial" size="2"></font>
Old 02-27-2013, 07:30 PM
unclecrash's Avatar
ORIGINAL: ACES&8s
Sorry for the late reply took a break from it for a while, plus lacking funds. Just had to get a new computer been living in the stone age way way to long. fans will be what I can afford at the time. Either C/S 12's or maybe a couple of the jetfan 90's
Old 02-27-2013, 07:37 PM
unclecrash's Avatar
ORIGINAL: backccopy
yeah,good info,<span style=''font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);''>Tails are ready for skins on the other side. Need to find so 1/16 balsa to build the skins. thanks</span><font face=''Verdana, Arial'' size=''2''> </font>
Yup need some balsa sheet. I cannot make up my mind if I want to pin them on and sheet after with no access hatch. Or make them removable so if I need to take them off I can. Probably will make them removable easier to sheet and glass that way.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
