Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Arado 234 B
Old 10-23-2013, 10:52 PM
Jeanskydive
Jeanskydive's Avatar
Default Arado 234 B
Hello I get plan from Casa da balsa for this Arado 234 C I convert to a B model , and the the balsa wood cut come from Larry as Clarich Kits,this Arado have a wing span 92 in., and I will use like two 90 to 120 mm fans, will see later , start with fuselage bulkheads and strigners, building in progress . Cheers
http://casadabalsa.com/DigitalPlans/...duct&id_lang=1
Name:	Redimensionnement de DSCN3911.JPG
ID:	1932472   Click image for larger version
ID:	1932473   Click image for larger version
ID:	1932474   Click image for larger version
ID:	1932475   Click image for larger version
ID:	1932476   Click image for larger version
ID:	1932477   Click image for larger version
Name:	Redimensionnement de DSCN2602.JPG
ID:	1932478   Click image for larger version
Name:	Redimensionnement de DSCN3861.JPG
Name:	Redimensionnement de DSCN3862.JPG
ID:	1932480   Click image for larger version
Name:	Redimensionnement de DSCN3863.JPG
ID:	1932481   Click image for larger version
Name:	Redimensionnement de DSCN3864.JPG
ID:	1932482   Click image for larger version
Name:	Redimensionnement de DSCN3865.JPG
ID:	1932483   Click image for larger version
Name:	Redimensionnement de DSCN3867.JPG
ID:	1932484   Click image for larger version
Name:	Redimensionnement de DSCN3868.JPG
ID:	1932485   Click image for larger version
Name:	Redimensionnement de DSCN3869.JPG
ID:	1932486   Click image for larger version
Name:	Redimensionnement de DSCN3870.JPG
Name:	Redimensionnement de DSCN3894.JPG
ID:	1932488   Click image for larger version
Name:	Redimensionnement de DSCN3895.JPG
ID:	1932489   Click image for larger version
Name:	Redimensionnement de DSCN3896.JPG
ID:	1932490   Click image for larger version
Name:	Redimensionnement de DSCN3897.JPG
ID:	1932491   Click image for larger version
Name:	Redimensionnement de DSCN3898.JPG
ID:	1932492   Click image for larger version
Name:	Redimensionnement de DSCN3899.JPG
ID:	1932493   Click image for larger version
Name:	Redimensionnement de DSCN3900.JPG
ID:	1932494   Click image for larger version
Name:	Redimensionnement de DSCN3901.JPG
Name:	Redimensionnement de DSCN3902.JPG
ID:	1932496   Click image for larger version
Name:	Redimensionnement de DSCN3903.JPG
ID:	1932497   Click image for larger version
Name:	Redimensionnement de DSCN3904.JPG
ID:	1932498   Click image for larger version
Name:	Redimensionnement de DSCN3905.JPG
ID:	1932499   Click image for larger version
Name:	Redimensionnement de DSCN3906.JPG
ID:	1932500   Click image for larger version
Name:	Redimensionnement de DSCN3907.JPG
ID:	1932501   Click image for larger version
Name:	Redimensionnement de DSCN3908.JPG
ID:	1932502   Click image for larger version
Name:	Redimensionnement de DSCN3909.JPG
Name:	Redimensionnement de DSCN3910.JPG
ID:	1932504   Click image for larger version
Name:	Redimensionnement de DSCN3916.JPG
ID:	1932583   Click image for larger version
Name:	Redimensionnement de DSCN3914.JPG
ID:	1932584   Click image for larger version
Name:	Redimensionnement de DSCN3933.JPG
ID:	1932742   Click image for larger version
Name:	Redimensionnement de DSCN3932.JPG
ID:	1932743   Click image for larger version
Name:	Redimensionnement de DSCN3944.JPG
ID:	1932794   Click image for larger version
Name:	Redimensionnement de DSCN3939.JPG
ID:	1932795   Click image for larger version
Name:	Redimensionnement de DSCN3947.JPG
Name:	Redimensionnement de DSCN3961.JPG
ID:	1933006   Click image for larger version
Name:	Redimensionnement de DSCN3957.JPG
ID:	1933007   Click image for larger version
Name:	Redimensionnement de DSCN39766.jpg
ID:	1933338   Click image for larger version
Name:	Redimensionnement de DSCN3979.JPG
ID:	1933339   Click image for larger version
Name:	Redimensionnement de DSCN3982.JPG
ID:	1933424   Click image for larger version
Name:	Redimensionnement de DSCN3996.JPG
ID:	1933577   Click image for larger version
Name:	Redimensionnement de DSCN3967.JPG
ID:	1933578   Click image for larger version
Name:	Redimensionnement de DSCN3985.JPG
Name:	Redimensionnement de DSCN3988.JPG
ID:	1933580   Click image for larger version
Name:	Redimensionnement de DSCN3994.JPG
Old 10-26-2013, 09:04 AM
danilo-2
Actual diameter (real life) of a Jumo 004 inlet was 18" at nacelle opening edges.
Size shape of inlets is The signature of the Jumo powered Luftwaffe jets,
any variance sticks out like dogs ' balls.
Your build is large enough to avoid that problem.. the inlets could be built to Scale.
Perhaps not using 110 mm units though.
Old 10-26-2013, 09:33 AM
Jeanskydive
Thank Danilo, I probably une two 90mm fans., all formers cut for the 90 mm , will see later ., I did the cover batterie access hatches and covering with 3/4 oz. fiberglass. , now the balsa sticks on is fuselage done, need a good sanding to get a perfect fuselage shape,. look good and verry strong with is laminate sticks. , working on is balsa block 2 X 4 for is shape in nose. Cheers
Name:	Redimensionnement de DSCN3973.JPG
ID:	1933254   Click image for larger version
Name:	Redimensionnement de DSCN3971.JPG
ID:	1933255   Click image for larger version
ID:	1933258   Click image for larger version
Name:	Redimensionnement de DSCN4021.JPG
ID:	1933717   Click image for larger version
Name:	Redimensionnement de DSCN3999.JPG
ID:	1933718   Click image for larger version
Name:	Redimensionnement de DSCN4001.JPG
ID:	1933719   Click image for larger version
Name:	Redimensionnement de DSCN4005.JPG
ID:	1933720   Click image for larger version
Name:	Redimensionnement de DSCN4006.JPG
Name:	Redimensionnement de DSCN4009.JPG
ID:	1933722   Click image for larger version
Name:	Redimensionnement de DSCN4010.JPG
ID:	1933723   Click image for larger version
Name:	Redimensionnement de DSCN4011.JPG
ID:	1933724   Click image for larger version
Name:	Redimensionnement de DSCN4016.JPG
ID:	1933725   Click image for larger version
Name:	Redimensionnement de DSCN4017.JPG
ID:	1933726   Click image for larger version
Name:	Redimensionnement de DSCN4018.JPG
ID:	1933727   Click image for larger version
Name:	Redimensionnement de DSCN4019.JPG
ID:	1933728   Click image for larger version
Name:	Redimensionnement de DSCN4042.JPG
Name:	Redimensionnement de DSCN4033.JPG
ID:	1933889   Click image for larger version
Name:	Redimensionnement de DSCN4034.JPG
ID:	1933890   Click image for larger version
Name:	Redimensionnement de DSCN4035.JPG
ID:	1933891   Click image for larger version
Name:	Redimensionnement de DSCN4037.JPG
ID:	1933892   Click image for larger version
Name:	Redimensionnement de DSCN4039.JPG
ID:	1933893   Click image for larger version
Name:	Redimensionnement de DSCN4040.JPG
ID:	1933894   Click image for larger version
Name:	Redimensionnement de DSCN4041.JPG
ID:	1933895   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4130.JPG
Name:	Arado twin jet new formers in the canopy.jpg
ID:	1935434   Click image for larger version
Name:	Redimensionnement de arado-234b_3d_model_d5e50944-2c6a-4a57-bf72-3734a63c5142.jpg
ID:	1935435   Click image for larger version
Name:	Redimensionnement de DSCN4121.JPG
ID:	1935437   Click image for larger version
Name:	Redimensionnement de DSCN4126.JPG
ID:	1935438   Click image for larger version
Name:	Redimensionnement de DSCN4132.JPG
ID:	1935440   Click image for larger version
Name:	Redimensionnement de DSCN4134.JPG
ID:	1935441   Click image for larger version
Name:	Redimensionnement de DSCN4138.JPG
ID:	1935442   Click image for larger version
Name:	Redimensionnement de Rotation de DSCN4167.JPG
Name:	Redimensionnement de Rotation de DSCN4144.JPG
ID:	1935548   Click image for larger version
Name:	Redimensionnement de Rotation de DSCN4148.JPG
ID:	1935549   Click image for larger version
Name:	Redimensionnement de DSCN4155.JPG
ID:	1935550   Click image for larger version
Name:	Redimensionnement de DSCN4157.JPG
ID:	1935551   Click image for larger version
Name:	Redimensionnement de DSCN4161.JPG
ID:	1935552   Click image for larger version
Name:	Redimensionnement de DSCN4162.JPG
ID:	1935554   Click image for larger version
Name:	Redimensionnement de DSCN4154.JPG
ID:	1935555   Click image for larger version
Name:	Redimensionnement de DSCN4176.JPG
Name:	Redimensionnement de DSCN4170.JPG
ID:	1935721   Click image for larger version
Name:	Redimensionnement de DSCN4171.JPG
ID:	1935722   Click image for larger version
Name:	Redimensionnement de DSCN4173.JPG
ID:	1935723   Click image for larger version
Name:	Redimensionnement de DSCN4186.JPG
ID:	1936003   Click image for larger version
Name:	Redimensionnement de DSCN4181.JPG
ID:	1936004   Click image for larger version
Name:	Redimensionnement de DSCN4184.JPG
ID:	1936005   Click image for larger version
Name:	Redimensionnement de DSCN4185.JPG
ID:	1936006   Click image for larger version
Name:	Redimensionnement de DSCN4221.JPG
Name:	Redimensionnement de DSCN4192.JPG
ID:	1936145   Click image for larger version
Name:	Redimensionnement de DSCN4193.JPG
Old 11-02-2013, 06:42 PM
Jeanskydive
Now l put is fuselage on the side and start the tail-plane and rudder, half of the fuselage done with 3/4 oz. fiberglass and resine wipe off, nex the canopy dummy lines, n complete stab., fuselage primer done ready, ,vertical and tail-plane also ready , so far so good. Cheers
Name:	Redimensionnement de DSCN4220.jpg
ID:	1936150   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4196.JPG
ID:	1936151   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4199.JPG
ID:	1936152   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4200.JPG
ID:	1936153   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4210.JPG
ID:	1936154   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4213.JPG
ID:	1936155   Click image for larger version
Name:	Redimensionnement de DSCN4215.JPG
ID:	1936156   Click image for larger version
Name:	Redimensionnement de DSCN4216.JPG
Name:	Redimensionnement de DSCN4217.JPG
ID:	1936158   Click image for larger version
Name:	Redimensionnement de DSCN4222.JPG
ID:	1936159   Click image for larger version
Name:	Redimensionnement de DSCN4233.JPG
ID:	1936176   Click image for larger version
Name:	Redimensionnement de DSCN4308.JPG
ID:	1936648   Click image for larger version
Name:	Redimensionnement de DSCN4274.JPG
ID:	1936649   Click image for larger version
Name:	Redimensionnement de DSCN4275.JPG
ID:	1936650   Click image for larger version
Name:	Redimensionnement de DSCN4276.JPG
ID:	1936651   Click image for larger version
Name:	Redimensionnement de DSCN4283.JPG
Name:	Redimensionnement de DSCN4284.JPG
ID:	1936653   Click image for larger version
Name:	Redimensionnement de DSCN4285.JPG
ID:	1936654   Click image for larger version
Name:	Redimensionnement de DSCN4287.JPG
ID:	1936655   Click image for larger version
Name:	Redimensionnement de DSCN4289.JPG
ID:	1936656   Click image for larger version
Name:	Redimensionnement de DSCN4297.JPG
ID:	1936657   Click image for larger version
Name:	Redimensionnement de DSCN4301.JPG
ID:	1936658   Click image for larger version
Name:	Redimensionnement de DSCN4303.JPG
ID:	1936659   Click image for larger version
Name:	Redimensionnement de DSCN4306.JPG
Name:	Redimensionnement de DSCN4278.JPG
ID:	1936661   Click image for larger version
Name:	Redimensionnement de DSCN4322.JPG
ID:	1936872   Click image for larger version
Name:	Redimensionnement de DSCN4318.JPG
ID:	1936873   Click image for larger version
Name:	Redimensionnement de DSCN4319.JPG
ID:	1936874   Click image for larger version
Name:	Redimensionnement de DSCN4320.JPG
ID:	1936875   Click image for larger version
Name:	Redimensionnement de Rotation de DSCN4387.JPG
ID:	1937357   Click image for larger version
Name:	Redimensionnement de DSCN4376.JPG
ID:	1937358   Click image for larger version
Name:	Redimensionnement de DSCN4378.JPG
Name:	Redimensionnement de DSCN4379.JPG
ID:	1937360   Click image for larger version
Name:	Redimensionnement de DSCN4380.JPG
ID:	1937361   Click image for larger version
Name:	Redimensionnement de DSCN4384.JPG
ID:	1937362   Click image for larger version
Name:	Redimensionnement de DSCN4385.JPG
ID:	1937363   Click image for larger version
Name:	Redimensionnement de DSCN4389.JPG
ID:	1937364   Click image for larger version
Name:	Redimensionnement de DSCN4390.JPG
ID:	1937365   Click image for larger version
Name:	Redimensionnement de Rotation de DSCN4386.JPG
ID:	1937366   Click image for larger version
Name:	Redimensionnement de DSCN4443.JPG
Name:	Redimensionnement de DSCN4447.JPG
ID:	1938480   Click image for larger version
Name:	Redimensionnement de DSCN4448.JPG
ID:	1938481   Click image for larger version
Name:	Redimensionnement de DSCN4451.JPG
ID:	1938482   Click image for larger version
Name:	Redimensionnement de Rotation de DSCN4436.JPG
ID:	1938483   Click image for larger version
Name:	Redimensionnement de DSCN4435.JPG
ID:	1938484   Click image for larger version
Name:	Redimensionnement de DSCN4438.JPG
ID:	1938485   Click image for larger version
Name:	Redimensionnement de DSCN4440.JPG
ID:	1938486   Click image for larger version
Name:	Redimensionnement de DSCN4441.JPG
Name:	Redimensionnement de DSCN4499.JPG
ID:	1939340   Click image for larger version
Name:	Redimensionnement de DSCN4507.JPG
Old 11-13-2013, 09:35 AM
Jeanskydive
Hello, vertical-fin in place , now working on is contour fin filet for smooth finish., landing gear done with 1/4 piano wire., and 5 in., main wheel, some camouflage paint, I put the fuselage on the side and start building is right wing pannel and sheeting with 1/16 balsa .Cheers
Name:	Redimensionnement de DSCN4579.JPG
ID:	1939335   Click image for larger version
Name:	Redimensionnement de DSCN4543.JPG
ID:	1939336   Click image for larger version
Name:	Redimensionnement de DSCN4568.JPG
ID:	1939337   Click image for larger version
Name:	Redimensionnement de DSCN45655.jpg
ID:	1939338   Click image for larger version
Name:	Redimensionnement de DSCN4582.JPG
ID:	1939339   Click image for larger version
Name:	Redimensionnement de Rotation de DSCN4584.JPG
ID:	1939543   Click image for larger version
Name:	Redimensionnement de DSCN4578.JPG
ID:	1939544   Click image for larger version
Name:	Redimensionnement de DSCN4598.JPG
Name:	Redimensionnement de DSCN4591.JPG
ID:	1940000   Click image for larger version
Name:	Redimensionnement de DSCN4600.JPG
ID:	1940001   Click image for larger version
Name:	Redimensionnement de DSCN4614.JPG
ID:	1940002   Click image for larger version
Name:	Redimensionnement de DSCN4619.JPG
ID:	1940003   Click image for larger version
Name:	Redimensionnement de DSCN4622.JPG
ID:	1940004   Click image for larger version
Name:	Redimensionnement de DSCN4615.JPG
ID:	1940005   Click image for larger version
Name:	Redimensionnement de DSCN4617.JPG
ID:	1940006   Click image for larger version
Name:	Redimensionnement de DSCN4633.JPG
Name:	Redimensionnement de DSCN4643.JPG
ID:	1940305   Click image for larger version
Name:	Redimensionnement de DSCN4646.JPG
ID:	1940306   Click image for larger version
Name:	Redimensionnement de DSCN4650.JPG
ID:	1940307   Click image for larger version
Name:	Redimensionnement de DSCN4683.JPG
ID:	1941041   Click image for larger version
Name:	Redimensionnement de DSCN4679.JPG
ID:	1941042   Click image for larger version
Name:	Redimensionnement de DSCN4691.jpg
ID:	1941043   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4694.JPG
ID:	1941044   Click image for larger version
Name:	Redimensionnement de DSCN4712.JPG
Name:	Redimensionnement de DSCN4711.JPG
ID:	1941046   Click image for larger version
Name:	Redimensionnement de Rotation de DSCN4779.JPG
ID:	1941958   Click image for larger version
Name:	Redimensionnement de DSCN4751.JPG
ID:	1941959   Click image for larger version
Name:	Redimensionnement de DSCN4753.JPG
ID:	1941960   Click image for larger version
Name:	Redimensionnement de DSCN4754.JPG
ID:	1941961   Click image for larger version
Name:	Redimensionnement de DSCN4755.JPG
ID:	1941962   Click image for larger version
Name:	Redimensionnement de DSCN4757.JPG
ID:	1941963   Click image for larger version
Name:	Redimensionnement de DSCN4763.JPG
Name:	Redimensionnement de DSCN4767.JPG
ID:	1941965   Click image for larger version
Name:	Redimensionnement de DSCN4770.jpg
ID:	1941966   Click image for larger version
Name:	Redimensionnement de DSCN4771.JPG
ID:	1941967   Click image for larger version
Name:	Redimensionnement de DSCN4774.JPG
ID:	1941968   Click image for larger version
Name:	Redimensionnement de DSCN4775.JPG
ID:	1941969   Click image for larger version
Name:	Redimensionnement de DSCN4778.JPG
ID:	1941970   Click image for larger version
Name:	Redimensionnement de DSCN4791.JPG
ID:	1942652   Click image for larger version
Name:	Redimensionnement de DSCN4792.JPG
Name:	Redimensionnement de DSCN4798.JPG
ID:	1942654   Click image for larger version
Name:	Redimensionnement de DSCN4783.JPG
ID:	1943143   Click image for larger version
Name:	Redimensionnement de DSCN4776.JPG
ID:	1943145   Click image for larger version
Name:	Redimensionnement de DSCN4802.JPG
ID:	1943148   Click image for larger version
Name:	Redimensionnement de DSCN4816.JPG
ID:	1943150   Click image for larger version
Name:	Redimensionnement de DSCN4827.JPG
ID:	1943151   Click image for larger version
Name:	Redimensionnement de DSCN4831.JPG
ID:	1943152   Click image for larger version
Name:	Redimensionnement de DSCN4832.JPG
Name:	Redimensionnement de DSCN4833.JPG
ID:	1943154   Click image for larger version
Name:	Redimensionnement de DSCN4805.JPG
Old 12-07-2013, 10:45 AM
Jeanskydive
Default Arado 234
http://youtu.be/ej8KL_DNzLc Hello , is nose gear installation complete, is rignt wing in progress., right wing planking with 1/16 sheet balsa, time now to start glue somes ribs.on is left wing panel, nex start is right wing nacelle. Cheers
Name:	Redimensionnement de DSCN4872.JPG
ID:	1945559   Click image for larger version
Name:	Redimensionnement de DSCN4881.JPG
ID:	1945560   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4869.JPG
ID:	1945561   Click image for larger version
Name:	Copie de Redimensionnement de DSCN4949.JPG
ID:	1945562   Click image for larger version
Name:	Redimensionnement de DSCN4857.JPG
ID:	1945563   Click image for larger version
Name:	Redimensionnement de DSCN4862.JPG
ID:	1945564   Click image for larger version
Name:	Redimensionnement de DSCN4952.JPG
ID:	1945565   Click image for larger version
Name:	Redimensionnement de DSCN4959.JPG
Name:	Redimensionnement de DSCN4964.JPG
ID:	1945567   Click image for larger version
Name:	Redimensionnement de DSCN4961.JPG
ID:	1945568   Click image for larger version
Name:	Redimensionnement de DSCN4983.JPG
ID:	1946372   Click image for larger version
Name:	Redimensionnement de DSCN4984.JPG
ID:	1946373   Click image for larger version
Name:	Redimensionnement de DSCN4973.JPG
ID:	1946374   Click image for larger version
Name:	Redimensionnement de DSCN4976.JPG
ID:	1946375   Click image for larger version
Name:	Redimensionnement de DSCN4978.JPG
ID:	1946376   Click image for larger version
Name:	Redimensionnement de DSCN4981.JPG
Name:	Redimensionnement de DSCN4982.JPG
ID:	1946378   Click image for larger version
Name:	Redimensionnement de DSCN4992.JPG
ID:	1947121   Click image for larger version
Name:	Redimensionnement de DSCN4990.JPG
ID:	1947123   Click image for larger version
Name:	Redimensionnement de DSCN4993.JPG
ID:	1947124   Click image for larger version
Name:	Redimensionnement de DSCN4994.JPG
ID:	1947125   Click image for larger version
Name:	Redimensionnement de DSCN4996.JPG
ID:	1947126   Click image for larger version
Name:	Redimensionnement de DSCN5000.JPG
ID:	1947127   Click image for larger version
Name:	Redimensionnement de DSCN5001.JPG
Name:	Redimensionnement de DSCN5002.JPG
ID:	1947129   Click image for larger version
Name:	Redimensionnement de DSCN5003.JPG
ID:	1947130   Click image for larger version
Name:	Redimensionnement de DSCN5076.JPG
ID:	1949160   Click image for larger version
Name:	Redimensionnement de DSCN5077.JPG
ID:	1949161   Click image for larger version
Name:	Redimensionnement de DSCN5078.JPG
ID:	1949162   Click image for larger version
Name:	Copie de Redimensionnement de DSCN5104.JPG
ID:	1949624   Click image for larger version
Name:	Redimensionnement de DSCN5080.JPG
ID:	1949625   Click image for larger version
Name:	Redimensionnement de DSCN5090.JPG
Name:	Redimensionnement de DSCN5093.JPG
ID:	1949627   Click image for larger version
Name:	Redimensionnement de DSCN5097.JPG
ID:	1949628   Click image for larger version
Name:	Redimensionnement de DSCN5103.JPG
ID:	1949629   Click image for larger version
Name:	Redimensionnement de DSCN5105.JPG
ID:	1949630   Click image for larger version
Name:	Redimensionnement de DSCN5106.JPG
ID:	1949631   Click image for larger version
Name:	Redimensionnement de DSCN5119.JPG
ID:	1949996   Click image for larger version
Name:	Redimensionnement de DSCN5108.JPG
ID:	1949997   Click image for larger version
Name:	Redimensionnement de DSCN5109.JPG
Name:	Redimensionnement de DSCN5111.JPG
ID:	1949999   Click image for larger version
Name:	Redimensionnement de DSCN5112.JPG
ID:	1950000   Click image for larger version
Name:	Redimensionnement de DSCN5113.JPG
ID:	1950001   Click image for larger version
Name:	Redimensionnement de DSCN5117.JPG
ID:	1950002   Click image for larger version
Name:	Redimensionnement de DSCN5186.JPG
ID:	1950901   Click image for larger version
Name:	Redimensionnement de DSCN5189.JPG
ID:	1950902   Click image for larger version
Name:	Copie de Redimensionnement de DSCN5170.JPG
ID:	1950903   Click image for larger version
Name:	Redimensionnement de DSCN5180.JPG
Name:	Redimensionnement de DSCN5196.JPG
ID:	1950909   Click image for larger version
Name:	Redimensionnement de DSCN5193.JPG
Old 12-09-2013, 07:36 PM
danilo-2
Surprisingly your build now resembles neither a B nor a C version.
Appearing as more of a green beluga rather than either an Arado 234B OR C.
Why..did you do this ?
Old 12-09-2013, 10:45 PM
Jeanskydive
Yes agree I will need to do some remodeling work on is nose later one, this part easy to get proper shape. , the right wing nacelle almost complete , 3/4 oz. fiberglass and resine for is right nacelle, joint wing together and start to build is left nacelle in progress. Cheers. ..............
ID:	1946370   Click image for larger version
ID:	1946371   Click image for larger version
Name:	Redimensionnement de DSCN5228.JPG
ID:	1950911   Click image for larger version
Name:	Redimensionnement de DSCN5231.JPG
ID:	1950912   Click image for larger version
Name:	Copie de Redimensionnement de DSCN5223.JPG
ID:	1950913   Click image for larger version
Name:	Copie de Redimensionnement de DSCN5226.JPG
ID:	1950914   Click image for larger version
ID:	1950915   Click image for larger version
ID:	1950917   Click image for larger version
ID:	1950918   Click image for larger version
Name:	Redimensionnement de DSCN5177.JPG
ID:	1950919   Click image for larger version
Name:	Redimensionnement de DSCN5182.JPG
ID:	1950920   Click image for larger version
Name:	Redimensionnement de DSCN5192.JPG
ID:	1950921   Click image for larger version
Name:	Redimensionnement de DSCN5194.JPG
ID:	1950922   Click image for larger version
Name:	Redimensionnement de DSCN5198.JPG
ID:	1950923   Click image for larger version
Name:	Redimensionnement de DSCN5209.JPG
Name:	Redimensionnement de DSCN5227.JPG
ID:	1950925   Click image for larger version
Name:	Redimensionnement de DSCN5284.JPG
ID:	1951751   Click image for larger version
Name:	Redimensionnement de DSCN5257.JPG
ID:	1951752   Click image for larger version
Name:	Redimensionnement de DSCN5263.JPG
ID:	1951753   Click image for larger version
Name:	Redimensionnement de DSCN5264.JPG
ID:	1951754   Click image for larger version
Name:	Redimensionnement de DSCN5274.JPG
ID:	1951755   Click image for larger version
Name:	Redimensionnement de DSCN5276.JPG
ID:	1951756   Click image for larger version
Name:	Redimensionnement de DSCN5278.JPG
Name:	Redimensionnement de DSCN5279.JPG
ID:	1951758   Click image for larger version
Name:	Redimensionnement de DSCN5281.JPG
ID:	1951759   Click image for larger version
Name:	Redimensionnement de DSCN5282.JPG
ID:	1951760   Click image for larger version
Name:	Redimensionnement de DSCN5283.JPG
ID:	1951761   Click image for larger version
Name:	Redimensionnement de DSCN5305.JPG
ID:	1952280   Click image for larger version
Name:	Redimensionnement de DSCN5246.JPG
ID:	1952281   Click image for larger version
Name:	Redimensionnement de DSCN5249.JPG
ID:	1952282   Click image for larger version
Name:	Redimensionnement de DSCN5285.JPG
Name:	Redimensionnement de DSCN5286.JPG
ID:	1952284   Click image for larger version
Name:	Redimensionnement de DSCN5289.JPG
ID:	1952285   Click image for larger version
Name:	Redimensionnement de DSCN5290.JPG
ID:	1952286   Click image for larger version
Name:	Redimensionnement de DSCN5291.JPG
ID:	1952287   Click image for larger version
Name:	Redimensionnement de DSCN5296.JPG
ID:	1952288   Click image for larger version
Name:	Redimensionnement de DSCN5298.JPG
ID:	1952289   Click image for larger version
Name:	Copie de Redimensionnement de DSCN5310.JPG
ID:	1952434   Click image for larger version
Name:	Redimensionnement de DSCN5311.JPG
Name:	Redimensionnement de DSCN5312.JPG
ID:	1952436   Click image for larger version
Name:	Copie de Redimensionnement de DSCN5307.JPG
ID:	1952437   Click image for larger version
Name:	Redimensionnement de DSCN5435.JPG
ID:	1954036   Click image for larger version
Name:	Redimensionnement de DSCN5426.JPG
ID:	1954037   Click image for larger version
Name:	Redimensionnement de DSCN5428.JPG
ID:	1954038   Click image for larger version
Name:	Redimensionnement de DSCN5452.JPG
ID:	1954039   Click image for larger version
Name:	Redimensionnement de DSCN5362.JPG
ID:	1954040   Click image for larger version
Name:	Redimensionnement de DSCN5363.JPG
Name:	Redimensionnement de DSCN5433.JPG
ID:	1954042   Click image for larger version
Name:	Redimensionnement de DSCN5361.JPG
Old 01-06-2014, 10:04 PM
Jeanskydive
Default Arado 234 B
Hi everyone , right engine done complete and test at low rpm, build left nacelle in slow progress., and fiberglass cloth and resine finish., and ading somes cheater holes so the fan could breathe a bit more, left nacelle complete , sanding nex. . , also use somes plastic push rods covers look more scale like, weight and balance nex to find a proper place to put is twin 10S-5000 LiPo., Cheers
Name:	Redimensionnement de DSCN5489.JPG
ID:	1955103   Click image for larger version
Name:	Redimensionnement de DSCN5490.JPG
ID:	1955104   Click image for larger version
Name:	Redimensionnement de DSCN5495.JPG
ID:	1955105   Click image for larger version
Name:	Redimensionnement de DSCN5499.JPG
ID:	1955106   Click image for larger version
Name:	Redimensionnement de DSCN5500.JPG
ID:	1955107   Click image for larger version
Name:	Redimensionnement de DSCN5504.JPG
ID:	1955108   Click image for larger version
Name:	Redimensionnement de DSCN5508.JPG
ID:	1955109   Click image for larger version
Name:	Redimensionnement de DSCN5509.JPG
Name:	Redimensionnement de DSCN5510.JPG
ID:	1955111   Click image for larger version
Name:	Redimensionnement de DSCN5514.JPG
ID:	1955112   Click image for larger version
Name:	Redimensionnement de DSCN5515.JPG
ID:	1955113   Click image for larger version
Name:	Redimensionnement de DSCN5516.JPG
ID:	1955114   Click image for larger version
Name:	Redimensionnement de DSCN5517.JPG
ID:	1955115   Click image for larger version
Name:	Redimensionnement de DSCN5518.JPG
ID:	1955116   Click image for larger version
Name:	Redimensionnement de DSCN5476123.jpg
ID:	1955117   Click image for larger version
Name:	Redimensionnement de DSCN5480.JPG
Name:	Redimensionnement de DSCN5481.JPG
ID:	1955119   Click image for larger version
Name:	Redimensionnement de DSCN5482.JPG
ID:	1955120   Click image for larger version
Name:	Redimensionnement de DSCN5483.JPG
ID:	1955121   Click image for larger version
Name:	Redimensionnement de DSCN5507.JPG
ID:	1955123   Click image for larger version
Name:	Redimensionnement de DSCN5589.JPG
ID:	1956293   Click image for larger version
Name:	Redimensionnement de DSCN5527.JPG
ID:	1956294   Click image for larger version
Name:	Redimensionnement de DSCN5541.JPG
ID:	1956295   Click image for larger version
Name:	Redimensionnement de DSCN5544.JPG
Name:	Redimensionnement de DSCN5546.JPG
ID:	1956297   Click image for larger version
Name:	Redimensionnement de DSCN5556.JPG
ID:	1956298   Click image for larger version
Name:	Redimensionnement de DSCN5562.JPG
ID:	1956299   Click image for larger version
Name:	Redimensionnement de DSCN5564.JPG
ID:	1956300   Click image for larger version
Name:	Redimensionnement de DSCN5566.JPG
ID:	1956301   Click image for larger version
Name:	Redimensionnement de DSCN5572.JPG
ID:	1956302   Click image for larger version
Name:	Redimensionnement de DSCN5573.JPG
ID:	1956303   Click image for larger version
Name:	Redimensionnement de DSCN5574.JPG
Name:	Redimensionnement de DSCN5576.JPG
ID:	1956305   Click image for larger version
Name:	Redimensionnement de DSCN5578.JPG
ID:	1956306   Click image for larger version
Name:	Redimensionnement de DSCN5584.JPG
ID:	1956307   Click image for larger version
Name:	Redimensionnement de DSCN5585.JPG
ID:	1956308   Click image for larger version
Name:	Redimensionnement de DSCN5606.JPG
ID:	1956593   Click image for larger version
Name:	Redimensionnement de DSCN5591.JPG
ID:	1956594   Click image for larger version
Name:	Redimensionnement de DSCN5597.JPG
ID:	1956595   Click image for larger version
Name:	Redimensionnement de DSCN5602.JPG
Name:	Redimensionnement de DSCN5614.JPG
ID:	1956705   Click image for larger version
Name:	Redimensionnement de DSCN5608.JPG
ID:	1956706   Click image for larger version
Name:	Redimensionnement de DSCN5609.JPG
ID:	1956707   Click image for larger version
Name:	Redimensionnement de DSCN5613.JPG
ID:	1956708   Click image for larger version
Name:	Redimensionnement de DSCN5625.JPG
ID:	1957340   Click image for larger version
Name:	Redimensionnement de DSCN5618.JPG
ID:	1957341   Click image for larger version
Name:	Redimensionnement de DSCN5620.JPG
ID:	1957342   Click image for larger version
Name:	Redimensionnement de DSCN5623.JPG
Name:	Copie de Redimensionnement de DSCN568867.jpg
ID:	1957829   Click image for larger version
Name:	Copie de Redimensionnement de DSCN5690.JPG
Old 01-16-2014, 07:54 PM
Jeanskydive
Hello . no time to come build is turtle deck center top wing center section, and finishing with 3/4 oz. fiberglass.,so far so good., I use somes plastic cover for is control push rods, weight and balance nex to find a proper place for is power twin 10S-5000 LiPo ,check the CG and the batteries balance perfect right at front leading edge , fixe also is E.S.C., batterie box install for two 10_S 5000 LiPo ,all the load is batteries is just into the center of gravite,.CG still at the same spot batteries or wit-out it,, same place , look pretty good,.finish to assemble the Aeronaut fan, I use JB-weld ,I made a short test run with is Aeromaut Turbo 3000 /110 mm fan,result is pretty good a bit more than one pound per LiPo., pull 12 pounds on scale test bench , Cheers
Name:	Redimensionnement de DSCN5737.JPG
ID:	1958589   Click image for larger version
Name:	Redimensionnement de DSCN5738.JPG
ID:	1958590   Click image for larger version
Name:	Redimensionnement de Fresh paint.jpg
ID:	1958591   Click image for larger version
Name:	Redimensionnement de DSCN5691.JPG
ID:	1958592   Click image for larger version
Name:	Redimensionnement de DSCN5692.JPG
ID:	1958593   Click image for larger version
Name:	Redimensionnement de DSCN5693.JPG
ID:	1958594   Click image for larger version
Name:	Redimensionnement de DSCN5695.JPG
ID:	1958595   Click image for larger version
Name:	Redimensionnement de DSCN5698.JPG
Name:	Redimensionnement de DSCN5699.JPG
ID:	1958597   Click image for larger version
Name:	Redimensionnement de DSCN5700.JPG
ID:	1958598   Click image for larger version
Name:	Redimensionnement de DSCN5702.JPG
ID:	1958599   Click image for larger version
Name:	Redimensionnement de DSCN5703.JPG
ID:	1958600   Click image for larger version
Name:	Redimensionnement de DSCN5704.JPG
ID:	1958601   Click image for larger version
Name:	Redimensionnement de DSCN5705.JPG
ID:	1958602   Click image for larger version
Name:	Redimensionnement de DSCN5706.JPG
ID:	1958603   Click image for larger version
Name:	Redimensionnement de DSCN5708.JPG
Name:	Redimensionnement de DSCN5709.JPG
ID:	1958605   Click image for larger version
Name:	Redimensionnement de DSCN5712.JPG
ID:	1958606   Click image for larger version
Name:	Redimensionnement de DSCN5713.JPG
ID:	1958607   Click image for larger version
Name:	Redimensionnement de DSCN5714.JPG
ID:	1958608   Click image for larger version
Name:	Redimensionnement de DSCN5716.JPG
ID:	1958609   Click image for larger version
Name:	Redimensionnement de DSCN5722.JPG
ID:	1958610   Click image for larger version
Name:	Redimensionnement de DSCN5725.JPG
ID:	1958611   Click image for larger version
Name:	Redimensionnement de DSCN5754.JPG
Name:	Redimensionnement de DSCN5746.JPG
ID:	1958934   Click image for larger version
Name:	Redimensionnement de DSCN5751.JPG
ID:	1958935   Click image for larger version
Name:	Redimensionnement de DSCN5806.JPG
ID:	1959267   Click image for larger version
Name:	Redimensionnement de DSCN5756.JPG
ID:	1959268   Click image for larger version
Name:	Redimensionnement de DSCN5764.JPG
ID:	1959269   Click image for larger version
Name:	Redimensionnement de DSCN5771.JPG
ID:	1959270   Click image for larger version
Name:	Redimensionnement de DSCN5772.JPG
ID:	1959271   Click image for larger version
Name:	Redimensionnement de DSCN5777.JPG
Name:	Redimensionnement de DSCN5788.JPG
ID:	1959273   Click image for larger version
Name:	Redimensionnement de DSCN5790.JPG
ID:	1959274   Click image for larger version
Name:	Redimensionnement de DSCN5794.JPG
ID:	1959275   Click image for larger version
Name:	Redimensionnement de DSCN5800.JPG
ID:	1959276   Click image for larger version
Name:	Redimensionnement de DSCN5803.JPG
ID:	1959277   Click image for larger version
Name:	Redimensionnement de DSCN5820.JPG
ID:	1959726   Click image for larger version
Name:	Redimensionnement de DSCN5811.JPG
ID:	1959727   Click image for larger version
Name:	Redimensionnement de DSCN5815.JPG
Name:	Redimensionnement de DSCN5371.JPG
ID:	1975057   Click image for larger version
Name:	Redimensionnement de DSCN5372.JPG
ID:	1975058   Click image for larger version
Name:	Redimensionnement de DSCN5375.JPG
ID:	1975059   Click image for larger version
Name:	Redimensionnement de DSCN6108.JPG
ID:	1975060   Click image for larger version
Name:	Redimensionnement de DSCN6109.JPG
ID:	1975061   Click image for larger version
Name:	Redimensionnement de DSCN6110.JPG
ID:	1975062   Click image for larger version
Name:	Redimensionnement de DSCN6111.JPG
ID:	1975063   Click image for larger version
Name:	Redimensionnement de DSCN6114.JPG
Name:	Redimensionnement de DSCN6115.JPG
ID:	1975065   Click image for larger version
Name:	Redimensionnement de DSCN6116.JPG
Old 03-04-2014, 08:35 PM
Jeanskydive
http://youtu.be/xHp4gmw1y0Y Test bench Aeronaut Turbo 3000 / 110 mm with 10S-5000 LiPo , I have 12 lbs,. http://youtu.be/q46Tx-aQ-xc with 88 amps, 3,200 watts,. ready to install into the is nacell and test run outside .,plane total weigth at 29 lbs. for 24 lbs both motors. pull.and 6,000 watts total , ready to go . Cheers
Name:	Redimensionnement de DSCN6162.jpg
ID:	1975070   Click image for larger version
Name:	Copie de Redimensionnement de DSCN64155.jpg
ID:	1975071   Click image for larger version
Name:	Redimensionnement de DSCN62444.jpg
ID:	1975072   Click image for larger version
Name:	Redimensionnement de Luftwaaffe color 1.jpg
ID:	1975073   Click image for larger version
Name:	Redimensionnement de Luftwaffe10.jpg
ID:	1975074   Click image for larger version
Name:	Redimensionnement de Luftwaffe15.jpg
ID:	1975075   Click image for larger version
Name:	Redimensionnement de Luftwaffe 2.jpg
ID:	1975076   Click image for larger version
Name:	Redimensionnement de Luftwaffe 5.jpg
Name:	Redimensionnement de Luftwaffe 6.jpg
ID:	1975078   Click image for larger version
Name:	Redimensionnement de Luftwaffe 11.jpg
ID:	1975079   Click image for larger version
Name:	Redimensionnement de turn 1.jpg
ID:	1975080   Click image for larger version
Name:	Redimensionnement de Blitz.jpg
ID:	1975081   Click image for larger version
Name:	Redimensionnement de DSCN6261.JPG
ID:	1975082   Click image for larger version
Name:	Redimensionnement de DSCN7196.JPG
ID:	1989531   Click image for larger version
Name:	Redimensionnement de DSCN7118.JPG
ID:	1989532   Click image for larger version
Name:	Redimensionnement de DSCN70877.jpg
Name:	Redimensionnement de DSCN7096.JPG
ID:	1989534   Click image for larger version
Name:	Redimensionnement de DSCN71155.jpg
ID:	1989535   Click image for larger version
Name:	Redimensionnement de DSCN71622.jpg
ID:	1989536   Click image for larger version
Name:	Redimensionnement de DSCN715366.jpg
Old 03-03-2018, 04:40 PM
CasadaBalsa
Ebersol Aircraft Designer
Casa da Balsa
