Freewing f-14 Jeti DS-24 Programming Please Help
Has anyone out there using a Jets DS-24 programmed the freewing F-14 Tomcat. I am trying to set mine up and it is giving me the BLUES!!! In spite of watching all the videos and reading the manual, I just can't get it to act right. After years of using Futaba, my brain chemistry is permanently altered and I can't seem to figure this out.
This us what I am trying to do;
1. Use the ailerons as spoilers where they go up only, without reducing the throw on the tailerons (I can do both or neither, but not jus one)
2. Full span flaps (ailerons and flaps droop as flaps)
3. Completely disable the flaps when the wing goes into swept position
4. Set up a condition where I get no ailerons and low rate tailerons when I sweep the wing (this I actually accomplished)
5. Set up elevator compensation for flaps
I am willing to start over from scratch If necessary
Please help
Thank you
Anthony
Please help
Thank you
Anthony
