Gap at blades and housing???
Hello
I am new to EDF Jets but have a very big question
All this is because I fly at 7000 ft
So I got the Avanty S from free wing I noticed a big gap between blades and the housing so what would happened if I reduce that gap??
Thanks to you help and answers
That's what I thought you might do, just make sure it will not come off as you need quit a few layers to fill the gap. I also did the same with few 70mm units in the past while experimenting, but found cutting slightly down different rotors was a more efficient way.
