Super Sniper questions
I have a HET Sniper that I am about to maiden. I just have a couple of hold-ups.
One is that I have taped the elevator servo on twice and it keeps coming loose. That would be very bad.... I would like to glue it on. I have seen people shrink wrap the servo and then glue it (so they can cut it out if necessary) or I can make a small mount for it and glue the mount to the fuse.
Anyone else have experience with this?
Second, the retaining dowels on the front of the wing really dont go into the fuse very far. I know they are short, but when I screw the wing on, it almost seems as if it pulls back a bit as I can see the dowels. the fact that they are so short, and I can see them exposed because the wing is not completely flush against the front of the saddle means that there is only a millimeter or two actually holding it on.
Any suggestions?
I'll see if I can get a pic.
Rob
Any suggestions?
Rob
