Ducted Fan SU-35 Super Flanker
Greetings,
I’ve got a fiberglass SU-35 Super Flanker model with the following specifications:
Length: 950 mm (37.4”)
Wing Span: 1000 mm (39.4”
Wing Area: 22 sq. dm
Flying Weight: 0.9 kg
Engine: 6600 kv
It came with two 66 mm ducted fanes with a shaft diameter of about 2.1 mm. The motor housing has a diameter of 28 mm.
My question is when they say “Engine 6600 kv” is this the required power from both motors or for each one?
Any recommendations on the motors, speed controllers, and batteries I should get for it?
Thank you.
Engine: 6600 kv
Thank you.
