HET Sniper 70mm EDF build
The wing is built with a wood spar out to about 3 inches from end of wings. The outline can be seen in a photo in an post above.
SK, CANADA
Hi Guys,
I've read a few reports of folding wings with high power setups, so why tempt fate!?! I want to run my wing strengthening mod past the Sniper experts to see if they think it will actually add some integrity to these wings.
I bored out a 3/16" hole about 2/3 into the wing at the thickest part of the wing. Plan to drizzle some gorilla glue into the hole, lightly coat a CF tube with glue, spray with water, and insert it. CF tube will be cut off the the root, and the wing epoxied together as per manual.
Remainder of the build pretty much stock. I'll be using 2 x 2S 3500 Lipos straddling the ducts above the wing, 2.4 Ghz, Het 2W-20, Het 6904, and Tsunami 72.
Pics attached.
Please let me know your opinions.
Thanks guys.
Marc
Pics attached.
Thanks guys.
Marc
QC, VENEZUELA
Hi everyone i have the sniper too and it´s a really fast mini jet and very fast as well. i haved to make a little mod to the landing system i add some wheels to it for take off and landing on the runway.
the setup that i´m using is:
- wemotec 480 70mm fan with 5 blade impeller
- Lehner 1530 motor
- 5S 4500mAh Align batterie. (split in two parts 4 cells all around the fan unit al the otherone in the front. this batterie setup is for balance)
- elevator servo it´s a HS-81MG
- aileron servos HS-125MG
- steering wheel servo HS-55
here are some pics
- Lehner 1530 motor
here are some pics
WV
I picked up 2 of these unassembled with no instructions. Do you have instructions??
Chuck
Chuck
I have been wanting to build this plane for a while and I am excited to finally get going on it. Here is a look at the kit and the components going into it.
Specs:
HET Sniper 70mm EDF
JR 6200 2.4GHz reciever
HET 6904 70mm fan
HET 2W-20 motor
Tsunami 72A ESC
Futaba 3154 digital micro servos
Flight Power 3700mAh 4s 25c battery
The kit itself has very few parts. I was a little shocked not to find any directions for the kit. There is an excelent online manual however. The ESC also didn't come with any instructions. Again there is an online manual on the HET site.
So far the only work done was to clear coat the fuse. It was kinda dull. I also cut out the canopy. It is a little bit small. The dry fit didn't look good at all. I am going to have to do some work there.
Specs:
HET Sniper 70mm EDF
HET 6904 70mm fan
HET 2W-20 motor
Tsunami 72A ESC
My Feedback: (20)
