Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
A-10 Warthog
Old 08-15-2009, 10:40 PM
tiggerracing's Avatar
Default A-10 Warthog
Just saw the A-10 West team perform at the Wings Over Wine Country airshow today and was blown away by its capabilities and was just woundering if there was an ARF rc version of this bad @$$ tank buster.
Ive seen the one that nitroplanes puts out and herd to many bad things about it.
Old 08-17-2009, 10:53 PM
Cajun Special's Avatar
Default RE: A-10 Warthog
Hobby Lobby has a VERY nice scale electric A10. Also try Electric Jet Factory.
Old 08-21-2009, 04:43 PM
rcmiket's Avatar
The problem is that there all either to small or too big. I had a GWS a few years back and hated it. I'm working on a 55 to 70 inch EDF right now. Were in the CAD mode on it right now and I'm hoping to get to the build shortly. Once I'm there I'll post the build here and RC Groups due to there more a electric crowd. I'll keep you posted.
Mike
Old 08-21-2009, 10:06 PM
HET just came out with an A-10 warthog, the manual was done by FanJetsUsa, I had the oportunity to fly the prototype during the manual construction phase while I was visiting my brother, very cool plane, twin 70mm fans. Right now it is availible in a gray version, easy to repaint if you want, we are talking to HET about a tan desert version coming out. Check it out at fanjetsusa.com
Old 08-22-2009, 07:32 AM
rcmiket's Avatar
Looks nice, just a bit small.
Mike
Old 08-23-2009, 05:41 PM
Cool thanks!
Why does money cost work "sigh"
Old 10-16-2009, 10:50 PM
I bought a Gl603-1 A10 from Nitroplanes, what I would like to do, is to remove the fans to balance them. How do I remove the fans? I've taken out the small screw at the front of the fan, and have tried to pull them off with my fingers, and have tried a small screw driver, but am afriad I'll break a blade.. Question, how do I remove the fans?, the plane is already put together.. Help
Old 10-17-2009, 08:08 AM
cyclops2's Avatar
You are falling into a common mistake about fan blades.
You will MOST LIKELY BEND & ruin the fan blade by trying or actually pulling it off. What do you have to then spin it up to FULL SPEED? What do you have that will press into the center hole all the way?? Prop balancers are NOT good for EDF work.
How are you going to accurately FORCE the blade back on?
It is a hopeless job at best. .........Lots of dumb luck is required.
A TINY piece of Scotch Tape CAREFULLY put on & off each blade then run up to about the same RPM is the only safe way to find the possible unbalanced blade.
DO NOT be suprised if you can NOT improve the balance. WORSE vibration on every blade says it is O K. ..............Stop trying to improve what you can not.
Rich
Old 10-19-2009, 10:55 PM
Give Chris a call, he has a very nice medium sized A-10 that he makes himself here in CA.
http://www.rcuniverse.com/market/item.cfm?itemId=553531
The website also has links to a video and build thread.
Mark
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
