My parkzone HABU
#202
FL
RE: My parkzone HABU
I added the eflite retracts without a gear door, lots of air flow, no overheating problems here:[link=http://www.youtube.com/watch?v=kF3au1C5OyE]
#203
OK, Flew with Turnigy 4000mah, 4s1, 30C batterys, Xps retract kit, Eflite retracts, pushing around 3.4 lbs in the Habu, still flys like a dream (yes thats kindof heavy I think lol). Stock power, Stock Motor
Here is a fun video I just did from last sunday's fpv and ground footage in 20 mph winds. Next video we will definitely use a tripod for the ground video part lol
enjoy.
[youtube]http://www.youtube.com/watch?v=g2qblDtUi-A[/youtube]
enjoy.
#205
FL
I looked at the hobby king retracts but I am huge fan of the Eflite based on their toughness. I had a gear down crash landing in which I landed flat very hard. The wheels sprang back and left skid marks on the underside of the wing being fully compressed back. The nose gear servo was damaged but all three of the retracts worked great. The other advantage of the Eflites is they sense an obstruction and shutdown. There are plenty of video on youtube of installers damaging the linkage of their retracts when installing the system and the wheels get hung up or smashed while the openings are refined. That is my 2 cents.
You can also look at: http://www.sonicelectric.com/Merchant2/merchant.mvc?
#206
FL
Hey, I have been reading through the entire thread. There is only one person I see using the venom power 4s 14.8v 3200mah 30c battery. How does it compare with size, weight, flight time? Does anyone have to change the CG or have to cut the foam for the battery to fit. I see them advertise for $64.99 on many sites.
I was looking at the venom power 14.8v 3600mah 50c and its twice the price weights 1.5oz more than the stock battery or the 32mah venom. Any ideas how this would affect performance.
I know these are alot of questions, but i just got my HABU and would like to get the best battery for the buck.
#207
NC
If you have to buy a battery(s) anyway, is there a reason why you would not buy a battery from HobbyCity? I'm just curious. You can get a comparable battery for $40 or less (not counting shipping). I've had great luck with them.
#209
FL
I went with the Venom battery because I wanted to pick up a couple spares in our local hobby shop because I wanted to get more flying time and less charging time. I found the Venom batteries to be a perfect fit in the Habu with no adjustments. I fly pretty conservatively and usually land with more juice than I could if I wanted to push it. The Venom batteries fly great. I recently ordered 3 Turnigy 3300mAh 4S 30C Lipo Pack batteries from Hobby King and I found they fly just as well. The Turnigy batteries are a slightly tighter fit than the stock Eflite or Venoms batteries but no modifcations were required. I would go with the Turnigys at $31.00 if you can wait.
#210
FL
I also want to put in E-flite retracts, so I wanted to make sure there was enough power to manage the extra receiver load. I was a bit sceptical about the turnigy batteries, but I am glad you confirmed its worth. I will order 3 now.
#212
AL
I also use Turnigy LiPo's and have had good luck with them. Also, the Turnigy Charger (150 watt size) has served me well. It's usually priced around $75 at hobbycity.
I just checked it at HobbyCity..unfortunately it's on backorder. Check it out. It's worth the wait. http://www.hobbyking.com/hobbyking/s...idProduct=7523
#214
NC
ORIGINAL: bradj11
#215
FL
I have had really good luck the with the Thunder AC-6, here is youtube link to a demo. http://www.youtube.com/watch?v=pQIancXVHV8
It is a Chinese knockoff and I have been giving it a workout for over a year without any problems. Since the price right I actually bought 2 of them. Check out the attached photos that show how I installed them on a ammo can. I wanted to be prepared to close and lock the lid in case of a fire. The AC or DC power option allowed me to connect the power cables to one AC cord.
They are going for $55 at http://www.hobbypartz.com/thac6smbachw.html
#216
FL
The display on the Turnigy charger looks identical to the Thunder AC-6 charger found at http://www.hobbypartz.com/thac6smbachw.html. I suspect they are using the same programming chip that was probably cloned in several units in the knock off world.
A big plus with the Thunder AC-6 is that you can run off AC or DC current.
#217
ORIGINAL: skirack
ATTENTION.
There are several chargers now entering the China market that look similar to the Accucel-6. These chargers are produced with cheaper FETs and unfortunately much less accurate and very unsafe. There has been reports of the copied chargers over-charging packs and not balancing correctly.
Our chargers have CE and RoHS certification, proving there safety. Plus, thousands of customers the world over have used our chargers with excellent success.
Your batteries are expensive. We understand this and thats why we will not carry low-quality charging devices.
#218
FL
Has anyone installed the new E-flite 10-15 size electric retracts kit into the HABU as yet (that is the set without a separate servo) ?
http://www.e-fliterc.com/Products/Su...ProdId=EFLG110
Could you please share your pics or installation video?
#219
Brad, there is a ply kit made for the Habu & Elite retracts with instructions:
http://www.xtremepowersystems.net/retract1.php
the kit :
http://www.xtremepowersystems.net/pr...=XPS-LCHABUKIT
the kit :
#221
Heres a video I put together flying around with the retracts going up and down lol
Yes I just posted this above ,, doh sorry for double post (yes im proud of it :-P)
#222
FL
Do we need to do any souldering to the Turnigy battery connectors to work with the HABU? I have a friend that bought this battery for his Hobby Lobby SU-34 and he said he has to soulder connections and it was a mess to strip back the plastic wrap from the battery to do so. I bought 3 3300mah 4s 30c batteries per recommendations for you guys.
#223
NC
ORIGINAL: vasek
..... Our chargers have CE and RoHS certification, proving there safety. .....
Second, there have been CE marks put on some of the Chinese products which do NOT mean European Compliance, instead it means "Chinese Export" There is a slight difference in the format of the CE mark, and is a clever ruse to fool some people into believing that the product has been tested to the European standards.
The manual should state exactly which product family standard the charger was tested to. This should include both EMC and product safety standards. Testing to these standards don't necessarily mean the product is a quality product, just that it met the required standards, and if it fails it will most likely fail in a safe manner.
You will also have to decide whether the lab that performed the tests can be trusted. That can be a long discussion in itself.
I will have to say that I have no reason to suspect these chargers will not perform well.
#224
First flight with the habu at the weekend.Really impressed.Stock setup with landing gear attatched,Wow does this thing move!!!!.Its my first electric jet I have done,normally fly nitro/gas.Thought I would try something new.Build was easy,clear instructions,goes togeather well.Looks great in the air.Fellow members at my club really liked it and its performance.Great Job Parkzone!!One happy customer.
Regards
OMRA
Regards
OMRA
