My parkzone HABU
My Feedback: (64)
WA
Ok so I picked up the new Habu yesterday and had it ready to go in about 15 minutes. I bought the bnf version but I Fly futaba 2.4 so I sold the receiver and got another battery. Run time with a 14.8 3300 35c hyperion was about 4-5 minutes. When I recharged the battery I was able to put a little more than 2200 in so it consumed 66-70 percent of the battery. This plane flies very well great aerobatics.... great low speed flying and very easy to land in my opinion. So I am pleased with this product...
That was the positives and here are the negatives although these may not apply to you but this is how I like my planes to fly. Vertical power not so great.... on a full speed pass point it straight up into vertical and it would stall out and nose over after about 50 feet. Top speed I would say it is about as fast as a gremlin about 80-95 mph 95 on the generous side.
My fix.... I have to have unlimited vertical and I would like top speed to be in the 115-140 speed so I will be trying differnt fan units and different motors. Possibly even a 5s or 6s battery as well.
I will have more info tommorrow I plan on at least running a 6s battery tommorrow. Will update this post then.
Kyle
Kyle
FL
awesome. i got mine the other day but its been miserable weather here really bad downpours but i plan to fly it sunday after work the weather is supposed to be much better then. i would love to see that thing with a 5s set up...should really haul. for the money that eflite motor is good but there are plenty better out there maybe mess with some NEU motors.
Hi!
I am a brandnew member of RC Universe.
I have been a pretty addicted heliflier for the last two years, but also wanted a plane to fly.
I wanted something fairly quick and challenging, because I am used to the adrenaline rush of heliflying/crashing.
I have tried my friends Stryker F27c (more powerfull motor) andit went well. Very fun!
Ialso wanted an easy to maintain plane, since heli repairs/maintenance takes so much time/money
I decided on the PnP Parkzone Habu. It is on its way to Norway from Espritmodels.
4 batteries from Hobbyking is ordered and hopefully arrives soon (out of stock)
Can't wait.
CYA!
Can't wait.
CYA!
My Feedback: (64)
WA
Well I got goosed by the weather man it has been nonstop misting all day along with showers so I will give a shot tommorrow hopefully I can catch a sunbreak
Kyle
Kyle
My Feedback: (64)
WA
I am not sure what the max voltage is for a bl15 but no you wont smoke a 60 amp speed control with 5 cell or 6 cell. These speed controls are actually rated at 80 amps. I put a amp meter between the speed control and battery with a 4 cell 35c 3300 battery and only pulled 46 amps. with 5 cell his 53 amps and 6 cell hit 63 amps. I know of alot of guys with electric pylon racing planes that run power 60 motors and 60 amp speed contols with 6s no problem. Maybe there is something I dont know???
My Feedback: (64)
WA
Here are the specs off of e flites website pertaining to the speed contol in the HABU so 6s is ok up to 75 amp burst.
60-Amp Pro Switch-Mode BEC Brushless ESC
Key Features
Up to 60-amp continuous current with proper air flow, 75-amp peak
5-volt Switch-Mode BEC circuit capable of 2.5-amp continuous current on any recommended input voltage
Drives up to 7 analog or 6 digital standard-sized servos, with the BEC on any recommended input voltage
3–6S Li-Po, 9- to 18-cell Ni-Cd/Ni-MH input voltage
Finned heat sinks
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V), or 70% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shut down if signal is lost or there is interference
Programmable timing—5 user-selectable ranges for use with a larger variety of brushless motors
Programmable throttle input range (1.1–1.9 ms or 1.2–1.8 ms)
Utilizes new smaller MOSFETs technology to minimize weight
Radio System Power On/Off Switch
Optional RS232 Serial Link available for programming
Pre-wired connectors—E-flite EC3 on battery input and 3.5mm female gold bullets on motor output leads
Key Features
Finned heat sinks
My Feedback: (64)
WA
Here are the specs on the motor so I think it will be ok on 5s questionable on 6s I would assume.... I will let you know if the bl15 goes up in smoke but I doubt it will. I am replacing it anyways so THROTTLE ON! lol
BL15 Ducted Fan Motor, 3600Kv
Key Features
Purpose-built for the Delta-V 15 69mm EDF (EFLDF15)
Ideal for 68–70mm EDF units requiring a 28mm diameter inrunner motor
Ideal for up to 850 input watts
High-quality construction with ball bearings and hardened steel shaft
6-pole design
Overview
E-flite's BL15 DF Brushless Motor is an ideal choice for products such as E-flite’s BAe Hawk 15 DF and other similar-sized ducted fan airplanes when using the purpose-built Delta-V 15 69mm EDF (EFLDF15). The motor will provide great performance in 68–70mm diameter fan units requiring a 28mm inrunner motor.
Specifications
Recommended Ducted Fan Unit: Delta-V 15 69mm EDF (EFLDF15)
Static Thrust: 1.7 lb on 3S (11.1V)—using recommended Delta-V 15
2.8 lb on 4S (14.8V)—using recommended Delta-V 15
RPM: 31,000 on 3S (11.1V)—using recommended Delta-V 15
40,000 on 4S (14.8V)—using recommended Delta-V 15
Brushless ESC: 50A—60A
Product Specifications
Type: 6-pole Inrunner Brushless
Size: 15-size for Ducted Fans
Bearings or Bushings: Two 4 x 10 x 4mm Bearings
Voltage: 11.1–16.8V
RPM/Volt (Kv): 3600
Resistance (Ri): .02 ohms
Idle Current (Io): 2.80A @ 10V
Continuous Current: 46A
Maximum Burst Current: 55A (15 sec)
Cells: 3S–4S LiPo power 10–14 Ni-MH/Ni-Cd battery
Speed Control: 60A brushless
Weight: 106 g (3.7 oz)
Overall Diameter: 28mm (1.10 in)
Shaft Diameter: 4mm (0.16 in)
Overall Length: 40mm (1.56 in)
Key Features
6-pole design
Overview
Specifications
Voltage: 11.1–16.8V
RPM/Volt (Kv): 3600
NY
The motor has a 46A spec limit or 750 W. Guys are getting right at that limit with just 4S.
The ESC isn't in the direct airstream (intake or exhaust) so it's asking for trouble to overdrive it. The motor will fry the magnets if it gets too hot and it's now being driven at it's limit at 4S.
Horizon's Dave E. said they tried a 5S combo and neither the motor nor ESC liked it.
So without mods, I think you're going to cook something.
FL
Yea without question. if im changing mine out in the future im putting a castle or somthing in there. ive seen guys smoke eflites by running regular specs...there good controllers but not one i would pick to push.
My Feedback: (64)
WA
I am going to give it a shot with the ESC but yah I am sure the motor wont appreciate it. It is pretty cold here so with my 4s runs and all that thrust blowing through the motor my motor was actually cold when i landed and checked it. It was 20 degrees outside.
NY
ORIGINAL: kyleandtavion
Kyle
Kyle
Did you mean to say 500 feet there? Mine gets a good 5 seconds after pull up till the vertical rolls get too slow for me and then I pull back into a reverse cuban, so I didn't let it stall. That's right in the neighborhood of 500 feet. I didn't test the top speed with a gun yet but I agree with your estimation.
Joe
My Feedback: (64)
WA
I meant 250 feet possibly three hundred I went inverted real hard from about 10 feet off the deck. I have triple rates setup with my transmitter it was on ninja mode when i pulled back. So it was a 90 degree manuever.
FL
i got to fly mine today. it was really windy and around 65 degrees. we ran its first flight with a thunder power 45c pack, went pretty good with it i also liked the balance of it (it was a 2250) second flight the stock eflite pack....it was ok didnt have the same punch which was a noticeable difference. the balance of it was waaaay more nose heavy(considerable difference in pack weight). even though its a small pack the weight and power of the 2250 4s 45c pack was worth it. i have some 4s 30c 2700s i wanna try, a little more weight but not alot, just going to have less punch.
all in all im really not that impressed with their stock pack...it was "ok" at best and personally i liked the plane more tail heavy it was capable of so much more still maintaining a good stability and tracking well.. but as for vertical i had at least around 250 feet before i pulled it around and it didnt stall out yet it still had momentum but was real windy so im curious on a calm day what i would get out of it.
My Feedback: (23)
If you guys want more speed. Chuck the stock power. Install the wemo fan, thin Mylar thrust tube. For 4s , use something around 3600-3800kv. Chuck those draggy fixed gears too! This ball park set up will put you 130-140.
NY
130 mph? I don't think so. This is a big plane. Yes for a small F16, but this is as big as a Twister with a thicker wing and displaces a lot of air when it moves. You gotta show me how you can get that speed on a 70mm fan with a 4S setup (level flight no cheating!)
The stock setup isn't bad. It will turn heads at any park the way it is now. I've got other faster birds if I want, but this one stock is plenty good as designed.
My Feedback: (30)
Key Features
6-pole design
Overview
Specifications
Voltage: 11.1–16.8V
RPM/Volt (Kv): 3600
Key Features
6-pole design
Overview
Specifications
Voltage: 11.1–16.8V
RPM/Volt (Kv): 3600
The Habu motor is a 3200 kv motor
My Feedback: (23)
wind junkie, like I said and I don't need to repeat it. Seen it flew it been there for a long time. Any engineer can figure out a foamy.
Happy flying and good luck!
[/quote]
NY
ORIGINAL: stoneenforcer
I need data with radar to back up what you're saying. All foam isn't created equal you know. Size matters
My Feedback: (64)
WA
Well I found what motor I want to use so here is my next question to all the EDF guys out there where is a good place to buy a neu motor? I went on there website and almost all the dealers they had were out of business or didnt have a clue about the motors??
Thanks for the input
Kyle
Kyle
My Feedback: (30)
[quote]ORIGINAL: bearcatf8
remember the plane is foam. Any heat from anything can and will melt it, results in a large smoking hole.
[/quote
REALLY? Cause I've seen turbines in and on planes like funjets, Twister's etc..been nothing but fun & no smoking holes!
[/quote
FL
foam? turbines? why not? seems like fun to me.
http://www.youtube.com/watch?v=hEmiz...eature=related
