B-52
1 Attachment(s)
I am working on this B52. It will have 8 55mm fan units and 4300 KV motors. The wingspan will be 94 in. with a 75 in. fusilage. I am planning to install robot retracts and four 5000mah batteries. I've posted some of my early pictures and will post more as I go.
RE: B-52
Whoua , nice project
RE: B-52
A friend of mine here is building one also. Built up balsa/ply, retracts (outriggers are electric), fowler flaps.
RE: B-52
My friend wants to know if you are doing a foam or built up wing.
RE: B-52
Hi, It is all foam wing with 3 carbon fiber rods shaped like a triangle and foam ribs for the support. There is a little ply used not much. The whole plane will be fiberglased and painted. I will put some pics on when building the wing. If your friend would like to see the wing assembled, I can send him pics. If anyone is interested I have a spare kit and instructions with step-by-step of how to build it.
RE: B-52
Thanks for the reply. My friend does not have a computer but I showed him your pics. So far he is building the wings. They are 7' each half with 4 70mm fans in the inboard pods only. The outbards are dummys. The outboard gear are electric. He has made fowler mechanisms for the flaps to extend 2 1/2" before going downward.
RE: B-52
Nice size model little biger then my. My can fly with four motors i makeing it more complicated if you can keep posting. I would love to see it completed thanks
RE: B-52
You must have a liking of american bombers. Thats a nice B-17 in the back ground. <div>
</div><div>Keep up with the building, very interested</div> |
RE: B-52
Thanks. yes the B17 , in my opinion, is the most historic Boeing aircraft ever built. The B52 has many similarities. I'll keep posting as I build.
RE: B-52
Are the fans scale diameter? Is this your kit, or someone else's. Looks cool. |
RE: B-52
Hi I have two kits as far as I know everthing is scale for this 1/26 model I pick them up from rcu member who made them. The retracts look a little small but they will work Building this one and will sell the other kit
RE: B-52
Long time, no posts... Any progress on this project?? Inquiring minds want to know !
Old Dawg |
RE: B-52
Hi Guys with the holidays and my dauther had a baby boy on December 19 are first grandchild so we are pertty excited. I will get started on it and finish it for the spring. I have every thing to complete it. Working on the batteries dont know yet how it will turn out I want to use two 5000 mah wire four motors on one battery test not good pull the batteries down fast so i will try four batteries split them two on four motors see if i can 2100 or2200 mah per motor . I will send more pics and keep posting step by step Thanks
RE: B-52
1 Attachment(s)
Here are my latest pictures...
RE: B-52
My last entry showed the wing assembly. The original design made the wing permanent to the fusilage, but I didn't want that since it would not fit in my SUV. I wanted to bolt the wings to the fusilage and be able to take them off for transporting.
RE: B-52
1 Attachment(s)
Here is the right wing with four motors hook up and test run. Every thing works all the BEC work and the wiring is all good next step is to build the left wing panel
RE: B-52
Looking good so far. My friend has his all framed up now and is working on vacu-forming the cowls.
RE: B-52
IF your frend can get some pics i would like to see. And may be get some ideas to share some information thanks JOHN
RE: B-52
Very Intense project. Good Luck!
Ryan |
RE: B-52
Wow...nice project. The B-52 is a classic. Wear it proud!
Blessings on the aircraft for a long service. |
RE: B-52
Use 40-40c batteries maybe. An 1800mah 40c can discharge at 72 amps...maybe realisticly 60-65. On a 55mm fan 600 to 700 watts is alot of good thrust. The math is 3 cell, or 4 cell. ( 3-cell )
http://www.hobbycity.com/hobbyking/s...idProduct=9937 this pack is 172 grams or 6 ounces x 8 equals 3 lbs. http://www.hobbycity.com/hobbyking/s...idProduct=9938 this pack is 222 grams or 7.83 ounces x 8 equals 3.915 lbs. This pack is in one of my 70mm jets and it's doing 650 watts nicely, not even warm after a full flight. (conversion from grams to ounces is divide grams by 28.35 equals ounces_) (or you can do kilograms times 2.2 equals pounds ) The four cell pack is more efficient and uses less current with the right motor choice. And uses less costly ESC's. 14.8 volt packs at 40 amps is about 600 watts. Do 50 amp or 60 amp ESC's. 8 of them add up in price. Turnigy TZ-85A have BEC of 5 amps each, and can be applied in parallel for 40 amps for the radio. An rX with a heavy power bus might be a consideration. Each Turnigy ESC is 40 bucks. I use the Cyclone outrunners. They can max out and stay cool by design, and they are good to excellent quality. this is the page with 3cell 4 cell specs http://www.pw-rc.com/product_info.ph...oducts_id/1750 With free shipping and 38 bucks x 8 equals $304.00 and Philip takes only PayPal, but it's a good conversion, the cost for currency exchange is absorbed by the seller. I hope I can be of further assistance... Ed |
RE: B-52
8 3 cell 1800 40c packs are $161.17 total from Hobbycity
8 85 amp esc's is $307.71 total from Hobbycity. 8 motors from Philip Workshop is $303.76 Under 800 bucks |
RE: B-52
Thanks guys for your input. Hobby Pople have 5000mah 3s 30c I hopeing to used four and hook the eight motors up . My next test will be to run the batteries in parallel and see if they will work. Each motor is runing about 450 to 500 watts at 30 amps the reason i'm used bec is to make sure no interference from the fans with a seperate power supply Iwill post some pics soon the right wing is about 90% if you have any info let me know
RE: B-52
1 Attachment(s)
Ok - I now have some pics of Bernie's build. Stats are: 110" long, wings 84" ea, Spring Air main gear & e-flight electric outboards. Typhoon 600 motors + 90mm fans in the inboard nacelles using 6s 5000 20c packs x4.
RE: B-52
1 Attachment(s)
4 fowler flap sections move aft 2 1/2" before extending. pics show flap mechanism and inner extended. Also outrigger gear and front main with steering.
RE: B-52
Hi CAPT G thanks for the pics outstanding great build are there any plans for that plane or is your frend designed love it
RE: B-52
1 Attachment(s)
Nope - he just drew it out on a big sheet of paper. Here is a motor, fan unit and the plug for the 16 vacuum formed nacelle pieces that must be made. Pic inside front of fuse shows where wings plug in.
RE: B-52
1 Attachment(s)
Hi CAPT G YOUR FREND IS A MASTER BUILDER JUST amazing I builted a B17G but i had a set of plans from Don Smith
RE: B-52
1 Attachment(s)
Here's what he came up with for the last electric fly-in.
RE: B-52
http://www.youtube.com/watch?v=COpuPhDS-kI
I found a youtube link with some articles on 55mm fans. Taking around 8 to 10 pounds from the fans best guess. |
RE: B-52
http://www.pw-rc.com/product_info.php/products_id/1751
I found some more data on 55mm fans, might be pertinent. On the 55 mm fan with Cyclone 5200 motor, a 3 cell at 38 amps makes about .6 kilo thrust. Thats 10.5 pounds altogether. Since the packs will be in the 4 pound ballpark, leaves you with some 10 or so pounds of build. I'm trying to get a better handle on the 55mm fans on Youtube as well. Seems like a little over a pound per unit, is the best of the expectation. If you are sharing a 5000mah pack for two fans, 2500mah per fan, 38 amps for .6 kilo will give some repectable flight time. Managing the power is a worry for me, on my jets. I have short flights, but I don't dig too far into the full capacity of my packs. I have made forced landings with EDF's and they're not pretty. I put a link up in the previous response for Youtube video of a test, gotta email the guy, what his motor/fan unit is. |
RE: B-52
1 Attachment(s)
Here some pics of the wings working with foam is not not that simple put all the BEC in the wings the batteries will go in the fuse . The next step is to put the retracts in
RE: B-52
I designed this model a couple years ago. There is a ton of info about the way I built it on RCgroups. javascript:mox();<div>
</div><div>If that link is messed up for some reason just search for threads started by Trbdsl96</div> |
RE: B-52
